    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-11-2016, 09:41 AM   #20596
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Phillip F View Post
xray's 2wd buggy stock setting in the rear is on 4 toe-in.
That's not what he's talking about....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-11-2016, 08:51 PM   #20597
Randog111's Avatar
Looking for help on B5M lite gearing.
Going to OCRC
13.5t lrp no timing.
What spur?
What pinion?
It's my son's car so it doesn't need to fly.
Thanks guys,
Randog111
Randog111 is offline   Reply With Quote
Old 08-12-2016, 02:43 AM   #20598
MiCk B's Avatar
Originally Posted by buckeye dan View Post
Has anyone run the +4 c mount?
Hi,
Run them on high traction astro with the narrow hex. Narrow hex keeps overall track width the same.
Car was better with the +4mm.
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 08-12-2016, 07:33 AM   #20599
buckeye dan's Avatar
Originally Posted by MiCk B View Post
Hi,
MiCk B. :-)
thanks i may try it on high bite clay this winter...
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 08-12-2016, 08:38 AM   #20600
Trader Rating: 15 (100%+)
Hi,
MiCk B. :-)
raising the C mount 4mm essentially raises the roll center, correct? If i'm not mistaken, inner camber ball stud spacers can somewhat achieve the same thing but not quiet the same.
radioctrlhead is offline   Reply With Quote
Old 08-12-2016, 08:39 AM   #20601
Super Moderator
You're not raising the C Mount 4mm....Your widening the rear inner pivot 2mm per side for a total of 4mm. You then run the 5mm rear hex instead of the 7mm to maintain track width.
Old 08-12-2016, 11:07 AM   #20602
Oh wow, that's interesting.
Old 08-12-2016, 11:38 PM   #20603
twindad98's Avatar
Trader Rating: 16 (100%+)
I'm thinking about moving my electronics to inline. Did you guys notice a difference?
TLR 22 3.0
TLR 22-4
TLR 22T 2.0
RC8.2e
Sticky Kicks RC - Voodoo Racing Cells - Dialed Hobbies
twindad98 is offline   Reply With Quote
Old 08-13-2016, 05:29 AM   #20604
eper's Avatar
Trader Rating: 14 (100%+)
so you guys are running the wider c mount to help the car rotate center off? on high bite im guessing
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-14-2016, 07:08 PM   #20605
twindad98's Avatar
Curious about this one my self. I've wondered about the GHEA +2mm inserts for the C mount. Just didn't want to pull the trigger on $30 inserts without knowing what they will do for handling.
TLR 22 3.0
TLR 22-4
TLR 22T 2.0
RC8.2e
Old 08-15-2016, 03:03 AM   #20606
eper's Avatar
ran them when i first got my 5m they made the car rotate more center off but also felt weird on a not super high bite surface. so i only ran them on very high bite surfaces. only get them if you run on that type of surface imo
new milford ct,
Old 08-16-2016, 10:32 PM   #20607
Any help/ suggestions much appreciated.
Looking for a good tuning base point for my motor. Running a trinity d4 with 69/30 ratio at ocrc. I'm trying to figure out what timing and gear ratio I should be in with this motor and track. It's a long shot but any help is appreciated.
I have the timing at 45 now and seems to really be a sweet spot. Any higher and the motor runs a bit too warm.
Trying to get even more punch and top end like the expert guys are doing. It clearly seems like the expert class has a few hidden tricks up their sleeves that the sportsman guys aren't in on or don't find it worth the effort? My fast lap is 22 seconds on the current layout with an average of mid 22s. Experts are in the mid 21s but I think it has to do with their motor program...
Also played with roll center by moving the inner rear ball stud spacer from 0mm to + 2 mm and it really woke the handling up around the turns. Really cool to observe these minor but noticeable changes in the cars performance.
Old 08-17-2016, 01:12 AM   #20608
thecman26's Avatar
Trader Rating: 98 (100%+)
Make sure your running the best battery kinda like the "pros" do, top of the line oiled ceramic bearings in the tranny at minimum, pucks, slipper eliminator, and the best tires and sauce. Finding the best line is also necessary along with carrying corner speed.
Have you asked the "Pro's" for advice yet? Ask Jason Snyder
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-17-2016, 02:00 AM   #20609
Phillip F's Avatar
Originally Posted by thecman26 View Post
..... Jason Snyder
I don't think he is a "pro".
Phillip F is offline   Reply With Quote
Old 08-17-2016, 02:04 AM   #20610
thecman26's Avatar
Didn't say he is, he DOES run at OCRC right? He would be easier to ask a question than say Spencer Rivkin. Just sayin...
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
