    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 08-02-2016, 09:41 AM   #20551
twindad98's Avatar
Trader Rating: 16 (100%+)
Default Droop
Originally Posted by aeRayls View Post
Yes, you typically use 22-22.5mm with the 3rd hole
Awesome thanks!
twindad98 is offline   Reply With Quote
Old 08-02-2016, 10:20 AM   #20552
Phillip F's Avatar
Trader Rating: 15 (100%+)
What's the advantage in adding a third hole?
Phillip F is offline   Reply With Quote
Old 08-02-2016, 12:22 PM   #20553
CrawJac's Avatar
Hello all, I just picked up a B5M Factory Lite and wanted to know what type or maintenance do you do and when?
I'm new to racing and this car so any/all advice is appreciated.
Edit: I race on an outdoor clay track
CrawJac is offline   Reply With Quote
Old 08-02-2016, 12:29 PM   #20554
I race on carpet, so all I do is blow the fuzz off, and check that the shocks, and gear diff aren't leaking fluid...
Scott R is offline   Reply With Quote
Old 08-02-2016, 12:51 PM   #20555
Phillip F's Avatar
Clean car... Avoid binding in moving parts... Setup... Setup... Setup.
Old 08-02-2016, 12:57 PM   #20556
My cars come almost all the way down after race days. Make sure bearings are clean and the drivetrain is free. Clean out all the clay that might still be stuck in crevices. Rebuild shocks. I'll usually freshen up my diff every few race days too.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 08-02-2016, 11:21 PM   #20557
thecman26's Avatar
Trader Rating: 98 (100%+)
Wow, that's a bit on the extreme side... Overkill? Definitely!
weekly maintenance? I just pull the battery out, clean it up, pull the tires off, clean the tires, and put the car in the storage box... That's it... Of course I do a visual inspection to make sure nothings obviously broken or binding.
Maybe every 4 or 5 months do a diff rebuild and shock rebuild. That's basically a race season for us. Usually don't keep a car for over a season...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-03-2016, 04:48 AM   #20558
I don't get to race weekly, so my cars sit for a few weeks between races. I take them down to make sure everything is fresh for when I do get to make it to the track. I'd still keep the same maintenance schedule if I could race weekly though. Gives me something to do, plus I always know my cars are ready to go. I wasn't suggesting that anybody else follow the same routine, just stating what mine was.
Old 08-03-2016, 08:11 AM   #20559
Default 14awg wiring
I have a b5m that weighs only 1275 grams, with a rs gen 2 esc, and a 13.5 x20 lrp motor, being used on a indoor carpet track.
Will 14awg wire be ok for motor wiring, going to use 13awg for the battery.
eazy70 is offline   Reply With Quote
Old 08-04-2016, 12:23 AM   #20560
thecman26's Avatar
Well clearly since your track doesn't follow rules or enforce them use whatever you have. Since your buggy is way way way under weight, 14ga should be fine.
Old 08-04-2016, 03:53 AM   #20561
I'm not racing in the club, I only go to the track to have fun, no racing. Either way I tried it and the 14awg are getting hot after only 1 minute. So I am going to try 13awg.
Old 08-04-2016, 08:23 AM   #20562
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Something seems strange there. With a 13.5 your wires should be ambient after 1 minute.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 08-04-2016, 08:36 AM   #20563
I thought so to, and I the esc in blinky mode too, and the motor timing is straight from the box.
Old 08-04-2016, 08:39 AM   #20564
Moderator
bds81175's Avatar
Is it just one of the wires getting warm? That could be a small short inside the motor.
Tekno RC
Old 08-04-2016, 08:46 AM   #20565
No all 3 are
