    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-26-2016, 11:10 AM   #20521
Trader Rating: 17 (100%+)
Originally Posted by JAE View Post
Did most this but will try the battery forward. Not something Ive seen others have to do with oher b5m lite's ive driven. Have white springs all the way around. Are there steering block shin adjustments or Ackerman adjustments on these? Thx all!
Ackerman is adjusted by adding or removing spacers under the balls on the steering rack.
The steering stops are just button head screws you can add to limit steering travel...See pic
Scott R is offline   Reply With Quote
Old 07-26-2016, 11:29 AM   #20522
JAE
Trader Rating: 28 (100%+)
Thx! I will check for steering stops. Is steering added by adding or removing shims under balls on steering rack
JAE is offline   Reply With Quote
Old 07-26-2016, 12:30 PM   #20523
I recommend downloading the manual from Associated, and starting with the Stock setup.
B5M Manual Download
Old 07-26-2016, 08:55 PM   #20524
JAE
Per manual, "If corner entry is too aggressive, try increasing Ackerman by...taking away shims from the steering rack"...
So, increasing Ackerman this way will decrease steering making turn in more stable? I'm not sure I'm interpreting this properly. I thought increasing Ackerman aided in a tighter turning radius? Sometimes the on power vs off power steering confuses me. I'm looking for a tighter turning radius in 90 and 180 degree turns (not high speed sweepers)
Old 07-26-2016, 09:40 PM   #20525
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
just try it and judge for yourself. I always fell like I have smoother steering with more washers and more aggressive with less. it is an easy change to just try.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-26-2016, 09:52 PM   #20526
Phillip F's Avatar
Trader Rating: 15 (100%+)
Picked up a 1 race day b5m lite for my 8yr old. Turning radius is wide. Tires were right. Checked kick up and its 25 degrees. added roll. Still seems like a wide arc. Anyone know if this is common? I have not built a b5m and would appreciate any tips. Thanks!
My B5m lite steers really well off power in 90 and 180 corners. And it's built according to the manual. I think you are just so used to your xray.
BTW... I used to run white springs all around .. when I changed to green springs at the back. I got more steering and on power rear traction in the corners ...that's with 1.7 pistons (27.5 wt) at the rear and 1.6 (30 wt) in front
Phillip F is offline   Reply With Quote
Old 07-27-2016, 12:52 AM   #20527
JAE
Thx all ! Think I am used to my xb2's. But, I've seen some b5m's with wicked steering.'I'll take the shims off and try then experiment with the caster inserts. Phil - hope to see you tmw .
Old 07-27-2016, 06:10 AM   #20528
tsair's Avatar
It depends on your driving style, but assuming you're not trying to slide the car around...
Classical line is to decelerate as you approach the corner, and arc towards the apex. Since you are slowing down, weight is transferring to the front and allowing the front wheels to grip and turn (off-power steering).
After you hit the apex, you will start to accelerate out of the corner, weight will transfer to the rear, but you will still be steering (on-power) because you are still going through the corner.
In general, more weight on the front end will improve steering. Off-power, if you need more steering, more weight transfer to the front end will improve steering. On-power, less weight transfer to the rear end will improve steering.
There are other things that affect steering, but this is the basic concept.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-27-2016, 10:28 AM   #20529
czrlaker's Avatar
Trader Rating: 23 (100%+)
Default Rear suspension question.
I run my B5m at a local carpet track. There are a number of jumps and the buggy performs well all around. Except in a section where there are two small whoop style bumps(inch and a half maybe two inch bumps) , if try and speed through there my buggys rear kicks up and over the front end so there I am relying on a Marshall to flip me over. What would help me here? Here is a video the section I am talking about is 11 seconds into the video (that's not me driving) you can see this guy's buggy rear end kicking up, mine is more dramatic. Any help appreciated
https://m.facebook.com/story.phpstory_fbid=1760952740813944&id=1709884492 587436
Keep in mind my buggy jumps like a dream everywhere else on the track. New to racing. Shocks stiffer/softer in the rear? Oil weight thicker/thinner? I am not running with any drag brake.
czrlaker is offline   Reply With Quote
Old 07-27-2016, 11:14 AM   #20530
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
The rear is packing up under high wheel rates. If you are running the 3x1.4 pistons try switching to the 2x1.7.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 07-27-2016, 12:11 PM   #20531
DennisNyholm's Avatar
I'd say you need to soften the rear oil or change pistons.
DennisNyholm is offline   Reply With Quote
Old 07-27-2016, 01:19 PM   #20532
czrlaker's Avatar
I'll try this. This would slow the dampening speed am I right?
Wouldn't that make it bottom out quicker causing the rear end to hit the ground and bump it up and over? Or am I thinking about it the wrong way?
Old 07-27-2016, 02:18 PM   #20533
Krio's Avatar
Trader Rating: 150 (99%+)
Depends why it is kicking. I couldn't find the video with the link you posted, but typically a bucking car is either caused by the chassis hitting because the suspension is too soft or the shocks packing up because they are too stiff. Without seeing the video, it's hard to tell which side of the equation is giving you the result.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 07-27-2016, 02:30 PM   #20534
czrlaker's Avatar
Thanks for the replies. https://www.facebook.com/story.phpstory_fbid=1760952740813944&id=1709884492 587436
Link should work. It was previously setup for mobile.
Old 07-27-2016, 06:28 PM   #20535
The video isn't working since it is embedded in Facebook. You need the direct link.
But if the chassis is bottoming out causing it to bounce off the bump, you may need to slow the rear suspension down. Thicker oil.
If it is popping off the bump due to the rear suspension not keeping up, you need to speed it up a bit. Thinner oil or different piston.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
