    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 07-08-2016, 08:40 AM   #20476
Trader Rating: 15 (100%+)
moving the rear hubs in the "forward" position to try it out. when should this really be used? I was comparing to humpty's set up and I understand he is doing some wacky things but he has his hubs forward not sure i like it as it rotates more than i'd like resulting in the rear sliding
radioctrlhead is offline   Reply With Quote
Old 07-08-2016, 09:47 AM   #20477
DennisNyholm's Avatar
Originally Posted by nbartlet1 View Post
Isn't that kind of a pain in the butt, do you have to solder and unsolder every time you want to take the battery out of your car and charge?
If your battery isn't a bullet connector battery, you might have trouble. Does yours just have a connector coming out of a soft pack battery? If so, most people use shorty 2s batteries with 4 or 5mm bullet connectors.
https://www.amainhobbies.com/team-orion-2s-carbon-vmax-110c-lipo-shorty-pack-battery-ori14076/p485226
DennisNyholm is offline   Reply With Quote
Old 07-08-2016, 09:58 PM   #20478
5tone's Avatar
I put my rear hub forward on tight/super high grip tracks , like carpets.
To get a more agressive car.
On a large and/or bumpy track , I prefer a longer wheelbase.
5tone is offline   Reply With Quote
Old 07-09-2016, 06:49 PM   #20479
Default Tuning
Hi all,
I just had my first day at the track and getting the feel for my car and wanted to get some tips.
What setting on the radio is good to adjust braking? I feel that my car slows down real slow when I brake. Or do I need to change the ESC programming? I have a black box 800z.
Also the car pushes in the turns. Sometimes I hit the pipes on the outside. What is good for this?
Finally, I flipped a few times sideways going into turns, like I had to much traction and the car catapulted over to one side. For example, making a hard left turn and the car flips over the two right tires.
Oh, also, whats a good starting tire for a track that is not loose but not clay? I used holeshots and someone told me they would be OK but wear really fast on this track.
Thanks.
nbartlet1 is offline   Reply With Quote
Old 07-09-2016, 08:07 PM   #20480
Not familiar with the 800z but you would normally adjust drag brake and maximum brake strength in the ESC, and brake EPA on your radio to get the feel you want. Pushing could be many things, maybe wrong tires or just taking the turn too fast. Pushing, traction rolling, etc. hard to make suggestions without seeing the setup, track, etc. Tires - talk to the guys at your track that are super fast and "hooked up" out there.
will5879 is offline   Reply With Quote
Old 07-09-2016, 08:17 PM   #20481
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The 800z does not have a max brake adjustment
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-09-2016, 09:11 PM   #20482
Phillip F's Avatar
I bet it's the throttle settings in your transmitter when you calibrate it with the esc. I made that mistake before. My EXP brake was in -30 when I calibrate the esc. It has to be in 0.
Phillip F is offline   Reply With Quote
Old 07-10-2016, 06:19 AM   #20483
the 800z has plenty of brakes. I would re-calibrate again.
Old 07-10-2016, 08:59 AM   #20484
Send a message via Skype™ to Cody227
Does anyone know what parts are needed to convert a B5m to 3-gear transmission?
I don't care about the milled motor plate and aluminium top shaft, so are they really needed or can I just flip around my old motor plate and reuse the old steel top shaft?
RC8b SC ~ B5m ~ B4m ~ Mini-Z
Cody227 is offline   Reply With Quote
Old 07-10-2016, 09:19 AM   #20485
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I believe the motor plate is attached to the gearbox using countersunk screws. So I don't think you can just flip it around. You want 91602 for black or 91603 for blue.
They changed the top shaft sometime during the B5's lifespan where the bearings were different sizes. So make sure you have the top shaft that accepts the 5x10x4mm bearings. You want 91606.
Otherwise, as I understand it you should be ok to make the switch from 4 gear to 3 gear.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-10-2016, 09:52 AM   #20486
Silverstonev8's Avatar
You could do this https://www.amainhobbies.com/team-as...90002c/p486628
Silverstonev8 is offline   Reply With Quote
Old 07-10-2016, 12:22 PM   #20487
Can someone please email me the shapeways 3 gear lcg transmission pdf instruction/template file? I installed it without drilling the 2 front holes and it's a huge improvement in handling/steering!! Very pleased, just wanted to drill the two front holes and could figure out where they go but using a template could be easier.
Jamescgreen08gmail.com thanks
dsms4ever is offline   Reply With Quote
Old 07-11-2016, 08:34 AM   #20488
Trader Rating: 18 (100%+)
Talking gear diff
I see the discussions on this thread on the ball diff/gear diff debate. Just curious what the latest thought is. I want to try the gear diff. Can never seem to get the ball diff right.
I run MOD on 2 surfaces: 1) small outdoor track/tight and technical/hard packed dirt with a little dust and 2) indoor track/clay/med to high grip.
anybody have a b5m gear diff in their box they want to sell?
rcnewbie418 is offline   Reply With Quote
Old 07-11-2016, 08:37 AM   #20489
anyone using the MIP rollers with the MIP shiny pucks in Mod? What kinda of live are you getting from the rollers and outdrives.
Old 07-11-2016, 06:36 PM   #20490
Trader Rating: 478 (100%+)
I use them with a "hot" 17.5 and I have yet to wear a set out. How mod are you talking?
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
