    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-19-2016, 05:47 AM   #20281
DennisNyholm's Avatar
Originally Posted by Slashn77 View Post
Do you guys really run that hot on the motor that you need to make all the adjustments and have to use a finnisher body just to run this fan for maybe 10* heat savings.
My Mach 3 even with 50* timing outside in this 75 degree humid MI weather and I never see above 125 F.
I run about 140 at the end of an entire battery pack without fan. I prefer to have a fan on there for the extra insurance since I under weight anyway. When I had the fan I wouldn't get above 115 at the end of a pack running 30/69 fantom Fr1 RS stator.
DennisNyholm is offline   Reply With Quote
Old 05-20-2016, 07:45 PM   #20282
Phillip F's Avatar
Trader Rating: 15 (100%+)
I ran 69/33 with an ECO "SlingShot" 17.5T and Promatch 2S 4600MaH ... I'm getting motor temps at 175 deg which is a bit high compared to you guys. The gearing is perfect for the track.... maybe it's just the cheap motor.
Phillip F is offline   Reply With Quote
Old 05-20-2016, 08:15 PM   #20283
Is that after a race or a full battery pack? If that is after a race then I would get a fan or adjust your gearing and timing and keep a close eye with a temp gun
Slashn77 is offline   Reply With Quote
Old 05-20-2016, 10:12 PM   #20284
Phillip F's Avatar
It's after a full battery pack not a race.
Old 05-20-2016, 11:20 PM   #20285
I bought the Revolution Design Bellcranks and have a question:
http://www.revolution-rc.com/our-pro...inium-set.html
Where do these 2 little discs/shims go?
man1ac is offline   Reply With Quote
Old 05-20-2016, 11:32 PM   #20286
3n90t's Avatar
It maybe a crush tube between the bearings in the steering rack. The AE alum. Set uses them
AE: B5, B5M, B44.3, B6D, B64D
Tamiya: MF-01X Suzuki Jimny JB23
3n90t is offline   Reply With Quote
Old 05-21-2016, 12:00 AM   #20287
Phillip F's Avatar
looks like spacers/shims for the ball studs
Old 05-21-2016, 03:01 AM   #20288
eper's Avatar
Trader Rating: 14 (100%+)
in between the bearings on the ackerman bar. so you tighten the screws down without binding bearings i been making shims like tht since back when i ran the b4. i do it on all steerin assembly bearings
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 05-21-2016, 09:47 AM   #20289
Phillip F's Avatar
what are the parts needed for my B5M Lite (3 gear transmission) to convert to 4 gear transmission? Part numbers would really help and what are the advantage and disadvantage?. FYI ... I run in an indoor clay track with medium to high grip surface.
Old 05-21-2016, 10:10 AM   #20290
If you run on med-high grip you don't need a 4 gear tranny. That would be for low grip, as it adds more rear grip.
Sean B. is offline   Reply With Quote
Old 05-21-2016, 11:23 AM   #20291
nubs's Avatar
Just finished up my B5 build.
Pretty darn happy with the way it came out.
nubs is online now   Reply With Quote
Old 05-21-2016, 11:28 AM   #20292
Phillip F's Avatar
so..if it adds more rear grip ... would that make the buggy in medium to high grip tracks accelerate faster though?
Old 05-21-2016, 11:32 AM   #20293
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Grip doesn't necessarily increase speed. Read the 1st page of this thread for 3/4 gear break downs.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-21-2016, 02:35 PM   #20294
Default Gear diff build
I decided to give the whole gear diff thing a try in my B5M. And I assembled the gear diff without any instructions, which may have been questionable on my part, but after some trial and error I got it together, and I LOVE IT....
But I noticed that the outdrives have some play in them and in my ball diff the did not. The diff doesn't move side to side within the transmission case so I don't see how adding the 1733 diff shims would help at all, but I just came across these instructions...
https://www.teamassociated.com/pdf/c...arDiffSupp.pdf
And it calls for 2 shims under the sun gears and let me tell you what! I tried to initially put 2 shims under the sun gear and there was NO way in heck that the round end pin would slide through the hole in the outdrive with 2 shims under it. So I installed one and tossed the remaining 2 aside.
But now I have that little bit of play and it's driving me crazy to think that perhaps gear diffs do in fact require 2 shims under the sun gears. Can anyone chime in on this, Thanks!
dsms4ever is offline   Reply With Quote
Old 05-21-2016, 10:47 PM   #20295
WOuld be highly interested in this list to! Bought a used B5M FL and want to suit it for our low traction dirt track!
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Papa88
