    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-15-2016, 05:34 AM   #20266
Originally Posted by nbartlet1 View Post
Hi, I just build my B5M kit (champions), and the rear springs rub the turnbuckles. They even look bent a little bit to get around them. I can't really figure out if/what I did wrong. The champions edition kit was packaged pretty poorly, so there is a chance I mixed some parts up, but I just don't know which ones would cause this?
Thanks!
Rear Hub must be put right !!!
change the left and right)))) checked on my model !!!
mitrich is offline   Reply With Quote
Old 05-15-2016, 06:48 AM   #20267
Thanks!
Need to flip the hubs....you have right hub on left side/vice versa
mgers75 is offline   Reply With Quote
Old 05-15-2016, 10:28 AM   #20268
Thanks everyone, simple fix!
nbartlet1 is offline   Reply With Quote
Old 05-15-2016, 12:39 PM   #20269
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by thecman26 View Post
Could you post up a pic? Yeah in buggy I never really needed one, I did have one but the 3D printed waterfalls were pretty weak and mine broke.
I just cut my existing waterfall and mounted a fan...
akura2 is offline   Reply With Quote
Old 05-15-2016, 12:44 PM   #20270
Just got my B5M FL used from a AE Driver Car is full option (look so sick). Cant wait to get it out to play
man1ac is offline   Reply With Quote
Old 05-15-2016, 01:25 PM   #20271
Suspended
Trader Rating: 61 (100%+)
I'd move the fan closer to the motor to give it a little more head space to pull air. Butted up against the battery kills the efficiency of the fan to pull air.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-15-2016, 07:03 PM   #20272
Trader Rating: 17 (95%+)
Send a message via AIM to JGruber
Just got a B5M, and I'm not sure what one it is, however it did come with a shapeways 3gear Laydown trans, I did see it requires you to drill 2 extra holes in the chassis. Howeve I have not been able to find a template for the holes, does anyone have a template for it?
My Gear...
U4RC 2.2 Trophy rig by RCFab Works
Team Associated B44.2
Lost Eight 3.0e
Futaba 4PX
JGruber is offline   Reply With Quote
Old 05-15-2016, 07:08 PM   #20273
Pville Stig's Avatar
Take the trans and make a template from it on paper. Did this with the red's laydown trans, works perfectly. Make sure to measure every thing out twice.
RC America/XRAY
LRP America
AKA Products
Pville Stig is offline   Reply With Quote
Old 05-15-2016, 07:16 PM   #20274
This is the plan, but I thought I would ask before I do that.
My Gear...
Lost Eight 3.0e
Futaba 4PX
Old 05-16-2016, 11:13 AM   #20275
You can take the trans out put it on a copier/scanner/printer and print out a copy. Then use that as a template. Or you can also use a clear folder cover ans do it that way. Hope this helps.
jneg is offline   Reply With Quote
Old 05-18-2016, 09:39 PM   #20276
Do you guys really run that hot on the motor that you need to make all the adjustments and have to use a finnisher body just to run this fan for maybe 10* heat savings.
My Mach 3 even with 50* timing outside in this 75 degree humid MI weather and I never see above 125 F.
Slashn77 is offline   Reply With Quote
Old 05-18-2016, 10:02 PM   #20277
Finalist's Avatar
What gearing are you running?
My car would be around 165 degrees or slightly more at 50 degrees timing on a reedy mach 3, 1S short stack, 17.5, geared 69/29, weight around 1508 grams.
With the same set up, weight and gearing and just changing to a Trinity D4 1s 17.5 cert motor and timing set to 58 my temps drop to 135. I still run a fan just for extra care which gets my Trinity set up down to 115-120, but the Reedy motor at 50 timing is hot.
Finalist is offline   Reply With Quote
Old 05-18-2016, 10:08 PM   #20278
I agree that cooler is always better just seems like a lot of work.
But I usually run 69-72/30-31 track depending for when I run 17.5. But the Mach 3 runs much cooler than my former Mach 2's and I run stock and mod 6.5 and 7.5 all Mach 3's
Old 05-19-2016, 05:10 AM   #20279
thecman26's Avatar
Trader Rating: 98 (100%+)
Same here, Fantom FR-1, barely gets up to 130* at 50* of timing indoors around 75-80* ambient temp. Plenty of speed and torque.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-19-2016, 05:11 AM   #20280
thecman26's Avatar
There's your problem, short stack, always run hot.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
