    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-11-2014, 10:40 AM   #1966
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by tropmonky View Post
I have an issue with that. Lots of batteries are different weights, thus you're not comparing the weight of the actual car itself which is what we are doing.
Some are running shorty packs, some are running pan car batts (lighter than shorty packs, mine is 150g) or a new SQ Brick pack...
Because of the different weights in battery packs it's best to weigh the car alone minus the battery.
well, if your going to go that route, you should remove the tires and rims also. Some of my tires weight greatly more than others. M4 holeshots weight more than a green barcode.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-11-2014, 10:50 AM   #1967
Trader Rating: 14 (100%+)
Electronics and body as well. That why you should compare the car you put on the track. That's what the rule looks at and really the only number that matters.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-11-2014, 10:54 AM   #1968
+1 the tekin gen2 I had was 40grams lighter than an orion and 20grams lighter than a viper. A LP servo is also about 20 grams less than a full servo. This is why we all just do race weight. All that maters if the roar min of 1499. And of the weight bias. Removing too much weight from one end of the car, could seriously effect traction.
Old 03-11-2014, 10:59 AM   #1969
Double Dee's Avatar
My b5m is not built so ill shut up...
Darin Duncan. @ TRCR/BRCR
Double Dee is offline   Reply With Quote
Old 03-11-2014, 11:01 AM   #1970
Send a message via ICQ to JiuHaWong
Why would you run 3.7volts in a buggy?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 03-11-2014, 11:13 AM   #1971
Originally Posted by suby723 View Post
I have noticed the same thing. I dont like the kit directions for the bleeding. Took me a few tries with different methods to get it dialed. I pretty much use that same bleeding process that you mentioned. Im suprised nobody else has mentioned this. I also use a tamiya pump to eliminate air.
Ya I found the best way for me and this way ther is no air
xTotalghost is offline   Reply With Quote
Old 03-11-2014, 11:27 AM   #1972
DKSPLIT96's Avatar
Originally Posted by Wild Cherry View Post
A great way to improve this sport is just open the buggy class for any motor & make Sc & ST 17.5 the new beginner class's..
BTW
Couple teammates are now using the shorty pack, mid performs much better with.
cherry, how are you orienting the battery? side to side? if so, in the front of the tray or rear? Or are you running it from front to back down the center of the tray?
Grant Beckwith
Associated, Reedy, Orion, Futaba
DKSPLIT96 is offline   Reply With Quote
Old 03-11-2014, 11:39 AM   #1973
It's a 2s Pan Car battery.
http://www.amain.com/product_info.ph...ts-74V-3200mAh
Stevenich is offline   Reply With Quote
Old 03-11-2014, 12:07 PM   #1974
Trader Rating: 20 (100%+)
Why not just try them out and see which one you like best?
Team Associated // Reedy
rc10gt82 is offline   Reply With Quote
Old 03-11-2014, 12:25 PM   #1975
predu's Avatar
a shorty will only fit sideways. have you built yours yet?
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-11-2014, 12:38 PM   #1976
Tech Legend
Wild Cherry's Avatar
place shorty in the rear of tray with 3/16 pad behind battery.
Don't what inline for mid , needs weight close to transmission .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-11-2014, 12:53 PM   #1977
lbckevin's Avatar
Trader Rating: 91 (99%+)
My mid motor weighed in at the JBRL at 1540g ready to run with everything and my transponder.
Weight is always measured ready to run on the track.
I mount my battery all the way back as well.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-11-2014, 01:02 PM   #1978
lbckevin's Avatar
Had fun at the JBRL race round 1 at IERC raceway. I raced stock buggy and stock truck. I won truck and took 3rd in buggy. There were 80 entries in buggy. I used my new Team Associated B5m buggy in the main and it was working great. I used Tekin power in both classes and MIP pucks in my T4.2 truck. My new Paint Monster truck body looks awesome
Kevin Smith
Old 03-11-2014, 01:05 PM   #1979
mxracer458's Avatar
Trader Rating: 47 (100%+)
cars look good kevin, i heard jbrl was a looong day.
mxracer458 is offline   Reply With Quote
Old 03-11-2014, 01:11 PM   #1980
lbckevin's Avatar
Sure was John...My mains started at 130am
Kevin Smith
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
