    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 04-09-2016, 01:14 PM   #19531
yea ill most likely go with the 17.5 with 800z since im still learning
eddie7978 is offline   Reply With Quote
Old 04-09-2016, 06:21 PM   #19532
JC8390's Avatar
My local track did a tech inspection today for stock class. Seeing my buggy on a scale was a little eye opening. She has a major weight problem lol. 1605g. How bad is that in stock buggy? I'm sure there is a point with weight reduction where it starts to get counter productive but most of the cars there were weighing around 1550.
How much difference would loosing 55g to get to 1550 make and how do I drop that weight??
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 04-09-2016, 06:24 PM   #19533
JC8390's Avatar
17.5 class, stock class, spec class...whatever you want to call it is very competitive but the car is much more manageable with the slower motor and more fun to drive in my opinion.
8ight E 4.0
RC10 B5M CE
Old 04-09-2016, 06:53 PM   #19534
Send a message via ICQ to intercede007 Send a message via AIM to intercede007 Send a message via Yahoo to intercede007
Race day!
Thanks to DennisNyholm, drag brake got my turn in issues sorted. I stayed out of the marshall's hands today, but there was no sportsmen class. Lots of laps where I got out of the way of the guys fighting for the mains so my lap times still sucked and weren't consistent.
All in all, the car is now pretty dialed after the drag brake. It's the nut behind the wheel letting it down now 100%
intercede007 is offline   Reply With Quote
Old 04-09-2016, 07:10 PM   #19535
Davidka's Avatar
Trader Rating: 75 (100%+)
How good are you at driving? If you're not "very" good, the weight difference might not to much for you.
FYI, legal minimum is 1,499g.
Old 04-09-2016, 07:23 PM   #19536
So I somehow stripped out one of the holes where the shock mounts to the rear suspension arm. I'll probably just buy a new set of rear arms, but is there any trick that will help me repair the threads so I can save the arm as a backup?
I was thinking about putting a drop of wood glue or something on the screw and then screwing it in and let it sit overnight. Thinking that might harden and tighten up the threads. But I'm not sure if I'll ever get the screw back out or if the threads will hold up since that's a screw that needs to be removed often. Might not be worth the effort but I'm just curious I guess.
Gearhead82 is offline   Reply With Quote
Old 04-09-2016, 07:27 PM   #19537
Good idea but for the price of the arms I would just grab new ones. No need to wrench down hard on screws into plastic, just snug.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 04-09-2016, 07:31 PM   #19538
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I'm right about that same point. Lower rotational mass is more important than overall weight. I'll take a good handling, snappy 17.5 car any day over an ill handling 1499 car any day. My older reflexes and eye sight don't allow for handling issues with my cars anymore.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-09-2016, 07:46 PM   #19539
Yeah I'm usually really careful when tightening into plastic but I was in a hurry and must have got careless. Still seemed like the threads gave out easier than they should have though!
Old 04-09-2016, 07:54 PM   #19540
aeRayls's Avatar
Mine wear out just because of taking my shocks off a lot! Just use a screw that's 2mm longer. There's plenty of extra room for it.
aeRayls is offline   Reply With Quote
Old 04-09-2016, 07:57 PM   #19541
When re threading into plastic always try and rotate the screws backwards slowly until you feel it drop into the old threads. Throwing it in and screwing each time you will cut new threads each time and after half a dozen times you will strip out the plastic.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-09-2016, 08:10 PM   #19542
mick33b4's Avatar
Couple drops of CA glue can get you by for a little while. Just put a couple drops in the hole, and gently tighten. Never had a screw not break free.
mick33b4 is offline   Reply With Quote
Old 04-09-2016, 08:43 PM   #19543
thecman26's Avatar
Trader Rating: 98 (100%+)
Back with my old B5M I felt 1535-1550 was the sweet spot. The lite comes in way less without any modifications. I will have to check and see what mine weighs in at ready to rock.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-09-2016, 08:50 PM   #19544
Kalio's Avatar
My buggy used to be 1605g, replacing all screws with (Lunsford) titanium and top shaft/wheel/shock nuts with (AE) aluminum got me down to 1575g. Planning to get a lighter battery next which will shave another 40-50g. Using standard (non-lite) chassis for lower center of gravity.
(Jason Shank)
Current: RC10B5m CE, RC10B44.3
Retired: RC10B4.2 RS
Tracks: Pitstop Hobbies, Bumps & Jumps
Kalio is offline   Reply With Quote
Old 04-09-2016, 09:06 PM   #19545
thecman26's Avatar
In my opinion the best weight you can lose is rotating mass, so schelle slipper, mip pucks, and cut gears. Next would be titanium turnbuckles and screws.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
