    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 04-05-2016, 10:36 AM   #19441
Default J Concepts Wing Mount
On the jconcepts thread they calin the wing mount is coming back in stock.
It says on this description it recommends the wing shim for added durability.
http://www.amainhobbies.com/rc-cars-...2356-1/p448783
For anyone that runs this already do you think the wing shim is necessary? deciding if I need it or not.
http://www.amainhobbies.com/rc-cars-...2357-1/p443485
caffeine357 is offline   Reply With Quote
Old 04-05-2016, 10:37 AM   #19442
Originally Posted by BRSracing View Post
thats the rumor, who knows for sure.
I think if anything more of a variation of the B5. I cannot see them coming out with a B6 when this one hasn't been out long enough. Just look at history, but then again I've been wrong once in my life.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 04-05-2016, 10:40 AM   #19443
AZJP's Avatar
Trader Rating: 20 (100%+)
Laydown cars have to run a saddle?
AZJP is offline   Reply With Quote
Old 04-05-2016, 10:59 AM   #19444
Finalist's Avatar
Shim seems like a lot of weight way up high?
Finalist is offline   Reply With Quote
Old 04-05-2016, 10:59 AM   #19445
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
roar requires buggies to fit a saddle/square pack or a full stick pack. IFMAR does not have that rule. hence the reason they were able to run it at the worlds. Now...will roar change the rule this year before nats? No idea. No idea if laydown will even be good at the nats track.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-05-2016, 11:03 AM   #19446
Trader Rating: 478 (100%+)
http://www.amainhobbies.com/rc-cars-...2357-1/p443485[/QUOTE]
I think that its unnecessary extra weight that you are adding to a high-spot on the car. Its a vanity item.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-05-2016, 11:07 AM   #19447
BRSracing's Avatar
Trader Rating: 53 (100%+)
The new Xray XB4 is not made to accept a saddle or full pack and it says ROAR approved. Not sure how that works? I thought the rule was as you stated.
BRSracing is offline   Reply With Quote
Old 04-05-2016, 11:09 AM   #19448
BRSracing's Avatar
I think that its unnecessary extra weight that you are adding to a high-spot on the car. Its a vanity item.[/QUOTE]
no you don't need it.
Old 04-05-2016, 11:11 AM   #19449
I am unsure what the car can or cant take. I checked the rule a couple months ago and it had not changed. When I talked to Brent about it, he made a comment about how they had tried to get the rule changes, but were unsuccessful. As far as I know the rule still stands, but maybe a change is coming soon?
Old 04-05-2016, 11:14 AM   #19450
http://www.roarracing.com/downloads/..._Rule_Book.pdf
page 37 near the bottom.
"All chassis in all electric classes (except those specifically noted) MUST accept
batteries up to the maximum dimensions allowed for its application. "
8.3.2.3.3 The maximum 2s brick/stick case::
Length: 139mm
Width: 47mm
Height: 25.1mm
8.3.2.3.4 The maximum 2s saddle case:
Length: 139mm to be measured as two packs end to end as a maximum
Width: 47mm
Height: 25.1mm
Old 04-05-2016, 11:30 AM   #19451
BRSracing's Avatar
Hanging on to that rule is so dumb to me. A AE Driver told me that is what held up the new 4x4 car. They wanted to see the rule change but ROAR would not budge.
Old 04-05-2016, 11:41 AM   #19452
I am just going off my conversation with Brent and what I see in the rule book. I have no idea what ROAR or AE has up their sleeve for the near future. AE may very well make a Euro spec car.
Old 04-05-2016, 12:01 PM   #19453
Trader Rating: 93 (100%+)
try 4wd front, really smooths out the car.
Sorry if this is a dumb question, but do you run 4wd front tires on the 2wd wheels?
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. -- F. Bueller
eddiemoney13 is offline   Reply With Quote
Old 04-05-2016, 12:06 PM   #19454
correct
Old 04-05-2016, 12:09 PM   #19455
ralphee's Avatar
The response to the question i asked them hinted at that, a high grip euro spec car!
Lee
ralphee is offline   Reply With Quote
