    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-01-2016, 04:58 PM   #19366
Originally Posted by Silverstonev8 View Post
Yes that one. What servo are you using? Does it place the servo in a different position than with the stock mounts? I wasn't thinking that I would have to cut to make it fit...
I use a 1258 of i remember correctly off the top of my head. No, it was just a tight squeeze. I run a CF chassis and I also cut the brace just behind the servo to gain just a little more room. I figured added that would restore a little more rigidity back.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 04-01-2016, 05:21 PM   #19367
Silverstonev8's Avatar
That makes sense since it ties both sides back together. I guess I'll see what I end up doing Monday when it shows up...
Silverstonev8 is offline   Reply With Quote
Old 04-01-2016, 06:43 PM   #19368
BLKXJ96's Avatar
Originally Posted by dustneyes View Post
I realize in the front wheels there are a lot of articulations that inherently cause slop, but I was wondering if anything helped.
You can also use the 3mm x 8mm (PN #4670) set screws that go into all the holes in the hubs front and rear as well. This makes the outer hinge pin/block insert tighter and takes a surprising amount of slop out of the suspension also.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 04-01-2016, 07:03 PM   #19369
Excellent info as well. I will also try that!
dustneyes is offline   Reply With Quote
Old 04-01-2016, 10:51 PM   #19370
JAE
Trader Rating: 28 (100%+)
Default Slop
Where did you find slop and how did you address it? Would be helpful for the group to have 1 bulletpoint list to reference.
Slop:
1: left rear hingepin: space between d mount and rear arm. Need to place shim/washer between rear arm and d mount. Also, Check inserts in c and d arm and replace when worn.
2:
3:
4
5:
Anyone else's added to the above most appreciated
Originally Posted by racer1812 View Post
Hmm of all the places I HAVE found slop, that really isn't one of them. Not to the point that I would ever spend $24 on 4 screws at least. That's CRAZY
The gear set inside my servo has more slop than my rack actually does. LOL
JAE is offline   Reply With Quote
Old 04-02-2016, 01:47 PM   #19371
every single bottle of AE shock oil no matter how much i seal it leaks the oil out eventually and the bottle is covered when i pick it up. does this seep through the plastic eventually? I cant seem to figure it out anyone have any suggestions?
caffeine357 is offline   Reply With Quote
Old 04-02-2016, 01:49 PM   #19372
I use avid wing buttons and screw right into the plastic. I didn't tap it. I just drilled it smaller and let the screw make its own threads to be tighter...
ill probably just get these as im tired of waiting for the set to come back in stock
Old 04-02-2016, 01:58 PM   #19373
General Maintenance Schedule Question
What schedule do you guys follow on your B5m for regular maintenance with the exception of stuff breaking of course.
After being called out by the local pros at my track after they looked over my shock oil and how the diff felt im curious with what frequency you guys look to adjust /replace stuff.
Main things I know so far to check are
shock oil (Every 2 races)
Bearings (Every 5 or 6 races)
slop in rear and front hubs
Old 04-02-2016, 02:32 PM   #19374
Do you use the air compressor? After you give it some air sit down and start wiggling parts I have caught numerous malfunctions in time. Often take your 2mm driver and just start searching
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 04-02-2016, 02:50 PM   #19375
So it came early. Servo fits well with no cutting. Car weighs in at 1585g
Old 04-02-2016, 03:25 PM   #19376
RCBuddha's Avatar
Trader Rating: 35 (100%+)
When I was able to race weekly, I would do the following:
shock oil - once a week if was dirty. I would always bleed/re-bleed my shocks before racing to make sure they were consistent.
Bearings: I run partially de-shielded, so I would clean and re-oil before every race
Diff: I would rebuild every week, but that's my personal preference. To clarify, rebuild = clean and regrease
slop: monitor after every race and shim as necessary.
YMMV depending on your track, the dirt, dust buildup, etc.
RCBuddha is offline   Reply With Quote
Old 04-02-2016, 04:16 PM   #19377
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Damn i guess im slacking! Shock oil once a year, bearings when they go out, Diff oil never unless it leaks.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 04-02-2016, 04:39 PM   #19378
Kalio's Avatar
I have the same problem. Trying to keep them stored upright seems to help I think. My guess is the cap just doesn't form a good seal.
Kalio is offline   Reply With Quote
Old 04-02-2016, 06:23 PM   #19379
once a year man, i hope youre kidding I dont see how your shocks would even fire they would be so gunked up
Old 04-02-2016, 06:26 PM   #19380
The diff every week is quite a commitment. I hadnt done mine since december so i can understand how i was slacking but man it takes awhile so hats off to you for doing it every week.
