    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-28-2016, 07:58 AM   #19291
chris c's Avatar
Trader Rating: 60 (100%+)
Compared to the B4 series of cars ...the 5 is 100x's stronger...it seems I used to break at least 1 arm every time I drove...keep it steady and you will start to understand the car and excel
chris c is offline   Reply With Quote
Old 03-28-2016, 08:11 AM   #19292
Has anyone seen this ad or recognize the image of the B5?
Is there a bigger version of the image?
I want to paint my B5 body the same way and I need a bigger picture to see the details
https://tpc.googlesyndication.com/si...82105538686672
tekin112000 is offline   Reply With Quote
Old 03-28-2016, 11:19 AM   #19293
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by NielsVV View Post
I made yesterday my maiden ride with the b5m on our local track. After the first jump I crashed and broke the rear shock mount! Spare parts were on order, so after only maybe 5min driving I went back home and ordered a couple more.
So far, I'm having some mixed feelings about the b5m.
Stick with it, my son has been racing this buggy in the novice class for a while now. I have seen him put his buggy in some pretty harsh crashes to where I can't believe nothing was broke and it keeps going. Anything is possible, bye has broke his share of arms as he continues to learn. I have never considered giving him a different buggy to drive..
TRCR, ARC r11 TC, hobbywing V3.1, TLR 22SCT™ 2.0, Team associated b6 buggy, futaba 4PX, Axial Wraith, Glamis Uno, Icharger 308, Simple Green, USMC
kjohnsiii is offline   Reply With Quote
Old 03-28-2016, 11:33 AM   #19294
I'm a beginner and I've been amazed at how durable the car has been through lots of crashes in my first couple months of racing. I haven't broken anything major. Just a couple odds and ends:
2 - bent rear shock shafts (at least one was from getting t-boned by another driver while I was flipped upside down)
1 - broken ball cup (pretty sure I cracked it while squeezing it with pliers to loosen it up during assembly and it later broke at the track)
2 - broken shock eyelets (from screwing them too far onto the shock shaft during assembly, I think)
1 - plastic rear camber insert block (shouldn't happen again now that I added a washer to the assembly, as suggested on this thread)
and of course I've destroyed a couple rear wings as well. . .
Gearhead82 is offline   Reply With Quote
Old 03-28-2016, 11:42 AM   #19295
JC8390's Avatar
I'm still debating on the MIP puck system.
http://www.amainhobbies.com/rc-cars-...p14230/p299223
If I go that route, I would get the MIP top shaft as well. Already have the cut gears.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 03-28-2016, 11:45 AM   #19296
soniccj5's Avatar
Very happy with the puck system. Worked well on the B4 and so far it is performing just as well on my B5M.
RC-10/ B4(+8mm)/
B5M FactoryLite|GTB3|Vulcan 17.5|MIP Pucks|Proline Primes|
B64D|510R|6.5 Vulcan
B6D|510R|7.5 Reedy
soniccj5 is offline   Reply With Quote
Old 03-28-2016, 05:56 PM   #19297
kjohnsiii's Avatar
What do you like about the MIP pucks? Do they last as long as the stockers?
Old 03-28-2016, 06:22 PM   #19298
lbckevin's Avatar
Trader Rating: 89 (99%+)
I still have my original pucks from the day they came out. I replace the orange parts about every 3 race days or if they are worn. I think they lighten up the drivetrain and provide quicker acceleration. Sometimes it causes too much wheel spin, but I alter my setup .
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-28-2016, 08:12 PM   #19299
what part number is it for shock tools from amain. don't have one
braderb is offline   Reply With Quote
Old 03-28-2016, 08:12 PM   #19300
Are those different rings than the kit comes with? A guy told me the seals need upgraded too? Seems like these shocks have a tendency to be leaky..
I don't believe the x rings came with it but others can correct me if I'm wrong. I built the proline shocks and used O ring grease from the link below and I don't have any leaks. I tend to rebuild mine often and keep everything lubed and very clean.
http://www.amainhobbies.com/rc-cars-...k-1410/p448398
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-28-2016, 08:16 PM   #19301
Just search shock pliers on their site and a bunch come up.
http://www.amainhobbies.com/search?cID=&s=Shock+pliers
I think they are over priced and the one I posted a page or two back is better and $14 but that's just my opinion.
B4.1
SC10
Losi SCB
Old 03-28-2016, 09:18 PM   #19302
Clarify
I need the shock tools that tighten the caps on.
My TLR ones don't work - TLR5099
Old 03-28-2016, 10:08 PM   #19303
Clarify
My post on the previous page shows one: Official Team Associated RC10 B5m Mid-Motor Thread
Up on the top right hand corner of this web page you can search key words in this thread. Chances are any issue you have has already been discussed. Search is your friend
You shouldn't need to completely wrench them down. Let the o rings do their job or else you will strip the cap.
B4.1
SC10
Losi SCB
Old 03-29-2016, 05:40 AM   #19304
The only tools I've been using for that are my fingers. Am I missing something?
Old 03-29-2016, 06:45 AM   #19305
I got these from A-main
You can use them to tighten shock caps but as others have said you have to be careful or you can ruin the cap.
Also, "the pliers also feature the ability to pop the shock end pillow ball in and out of place thanks to the ingenious stepped post built into the pliers. The stepped post fits 1/10 and 1/8 scale ball sizes. " This little thing really works well
http://www.amainhobbies.com/rc-cars-...k-8267/p248643
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
TeamSlacker
