Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
I used the AE plastic horn and on the XP1015 it was always tight. On the Sanwa and Orion servo it was better. Never cared for the aluminum horn when I tried it, no reason just didn't like it. I might try the Losi next time but always have so many AE ones sitting around just stick it on.
Super Moderator
Trader Rating: 31 (100%+)
I won't spend $200+ to "test" Ti screws either. Maybe spend that trying different brands as I build new cars but not actually "testing" 3 different brands on ONE car. (I'm obviously tying the previous question about testing Ti screws into this post)
Fair enough. I personally still won't spend $80 vs. $12 from AE just because it might be quieter. But that's me.
Only happens if you over tighten it when first threading it in. You are probably ruining the threads day one. I have never seen this happen in an absolute SEA of AE 1/10th buggies over the last 5 years. Heck, even my wife learned to drive in a B4, and could crash like nobodies business, and still never saw this. Heck, most novice crashers I have ever witnessed over the last countless years all started in B4s or SC10s... never seen this. Odds are even lower in a B5. B5 plastics, even the horns, are fantastic.
(and watch the language please)
If that's your experience and opinion I'm not going to debate it with you. You're certainly entitled and I respect that. But I can't say it's normal or common place either. I've seen very few, if any, issues with the stock AE horns.
fyi, I try to keep TLR parts OFF my AE rides............
haha, I have never messed up a full metal gear servo, but of course it adds more stress. I was just laughing at your made up statistics. Heck, I know a guy that snapped the alum steering cranks in the B5. But his servo and metal servo horn were fine.....
Tlr servo horn
I also run the tlr servo form on my car with no issues.
Let me start by saying sorry if this has been answered but i dont feel like searching through 800 pages. I want to run a setup like Hartsons where the battery brace is removed and i can run the esc and receiver in the center of the car. My question is how does the battery stay in place with no mounting bracket since the brace is removed? Is it just wedged between the esc and rear brace?
I agree with wildcat. Tlr aluminum horn is the way to go
I sand new ones and old ones. Some times new ones have crap on them. I rarely buy rings. I just use the ones in the kit and keep sanding them. It doesn't hurt to measure the thickness around the rings with a digital caliper or mic after a few sandings to ensure they're not getting non-uniform. I tend to keep a set of rings around just in case, and if I have to buy new balls, which is pretty rare, I get rings too just to be safe.
Wayne
Wayne
Yep. Sounds about the same here. I bought this car used 5 weeks ago. Just now had time to go through the car and find out the setup plus redo the diff. My B5-R still has the same diff from October '14 and feels good.
I use an old outdrive, 600 sandpaper, and do several figure 8's to get a crosshatch on the rings for traction.
I've never mic'd the rings but actually had that thought tonight.
