    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-05-2016, 03:11 PM   #18721
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Matt Trimmings View Post
Not a fan of pucks...they do lighten rotating mass but they take away traction as well
loss of traction..
ummm no loss here and big difference on acceleration
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 03-05-2016, 03:27 PM   #18722
DennisNyholm's Avatar
Originally Posted by JEFFs SC10 View Post
loss of traction..
I'm hoping so as I just placed an order for some!
DennisNyholm is offline   Reply With Quote
Old 03-05-2016, 03:49 PM   #18723
JEFFs SC10's Avatar
Trust me bro, you'll love them. wakes the car up!
XRAY 2017 T4
Xray X12-17' GT12
Old 03-05-2016, 04:09 PM   #18724
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Yes, less weight over the rear end but the main thing is less bone bind with the outdrive.
Same premise as when we ran plastic outdrives in the xxx series cars years back. Image is from the xxx manual.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-05-2016, 04:24 PM   #18725
JC8390's Avatar
http://miponline.com/store/mip14230.html
These?
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 03-05-2016, 04:26 PM   #18726
JC8390's Avatar
http://www.speedysracingparts.com/
Anyone try to gears from these guys?
8ight E 4.0
RC10 B5M CE
Old 03-05-2016, 04:52 PM   #18727
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Yes. They work well. I used to buy my b4 gears from them as well.
RCBuddha is offline   Reply With Quote
Old 03-05-2016, 05:21 PM   #18728
Default Setup help
I'm looking for help for 8.5 setup on outdoor, low traction, dusty dirt track. The car has the kit setup but I can't get enough traction. Tires are hole shot m3 front and m4 rears. I checked petit RC for setups but it's not clear which dirt surface resembles the one I run on.
astgerma52sp is offline   Reply With Quote
Old 03-05-2016, 05:25 PM   #18729
Trader Rating: 478 (100%+)
I've been using the shiny pucks with the rollers. I'm very happy with it. Its not quite as light but the rollers make it very smooth. I don't think that I'll use the regular pucks anymore.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 03-05-2016, 07:19 PM   #18730
team green's Avatar
They are good quality.
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Tamiya TA07 Pro
Associated B6
TLR 22-4 2.0
team green is offline   Reply With Quote
Old 03-05-2016, 08:09 PM   #18731
JEFFs SC10's Avatar
obviously you never ran MIP's.
XRAY 2017 T4
Xray X12-17' GT12
Old 03-05-2016, 08:14 PM   #18732
Yup they are good and I also use the MIP pucks.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-05-2016, 08:26 PM   #18733
Super Moderator
I have ran them. Same situation as what I posted. Not everyone can tell the difference. There is a reason not everyone uses them. Out here the majority of stock racers don't. On a very high bite track the slight loss of rear bite can be a benefit. It's not a night and day difference
Old 03-05-2016, 08:31 PM   #18734
mick33b4's Avatar
Check my prior posts in this thread. Ray Munday setup guide is a great start. Key items are B5R rear arms with hubs forward, green springs all around, 1.7 pistons 30/35 R/F, 3.5 deg rear toe. Also, I only run Hole Shot fronts if the grip comes up after we wet the track down. Otherwise too much steering. When it's dry and dusty, JC Rips fronts limit the oversteer. For really dry/loose I like proline Blockades or Bow ties in the rear. Some guys in this thread like the brass rear weights, but my personal opinion is it causes too much rear pendulum and oversteer. Also read posts by user Razathorn about link positions.
mick33b4 is offline   Reply With Quote
Old 03-06-2016, 03:15 AM   #18735
I am finishing building my b5 cry and I have an issue at last steps : on the 4 gears motor mount there is no thread pitch for the gear cover. Hence the screw can go in... I try to push hard to try make the screw start a thread but it does not work.
Am I re first one having this issue ?
It is strange because in second motor mount for the 3 gears configuration there is a thread pitch for the gear cover.
julieng is offline   Reply With Quote
