    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 03-01-2016, 08:00 PM   #18646
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by JEFFs SC10 View Post
When Dirt webs are worn in the middle they are perfect. Use a good tire sauce , personally I love love love SXT 3.0
Bar Flys, Type O's when brand new are great tires for high bite, compacted clay. Sauce em up and run 2 or 3 laps and they should ready to go. We run those, ghost slick Dirt Webs or slicks at our track.
Run some new Dirt Webs that extra bite will most likely solve 90 pct of your problems. They should last a good amount of time, but you'll need to get them scrubbed in before they really start gripping good.
Like everything track time and experimenting there and talking to the local fast guys to see the setups and tires they run, will yield the best results.
Try a change run a few laps and make notes before making another change.
What track do you run?
Dirt webs do need a break in especially dirt tech foams. Electrons are good to have as a backup while they break in. I run both at the beginning of the night and pick which one works best since they are both great tires.
JC8390 If your losing your ass end one item to double check is steering DR. If your at 100 and you have more then enough drop it a few points until you have to bring it back the other way. I have had ass end rotate and quickly get out of sorts because I had so much front grip and steering. When I calmed it down in front things calmed down. Last race though my rear was good changed tires and went to what felt like over steer to a quick ass end slip out, back to other tires and peas and carrots again so tires are 90percent.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 03-02-2016, 07:05 AM   #18647
JC8390's Avatar
Going to try that as well.. I have so many things to try lmao. Its going to take some time to work through it.
Right now, Ive left everything alone.. but I fixed my radio problem. Basically what I did is... my buddy calibrated the esc when I first set up the electronics. The throttle travel was at 100%. Then after that, I put the travel to 150%...so I believe the buggy is seeing full throttle somewhere around 75% trigger. Going to work from there this Friday lol.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 03-02-2016, 08:02 AM   #18648
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Make sure your front tires are good too..too soft of an insert can cause it to grab weird. Tires are literally 90% of a setup, maybe even more than that indoors.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-02-2016, 09:51 AM   #18649
AMitchell05's Avatar
I just bought a B5m Champions edition, from A-Main, to run 17.5 stock buggy class. What upgrades should I get for it? As in like aluminum jconcepts parts & etc. Also what bodies are everyone using? I like the look of the jconcepts warrior, but I seen a lot of people running the JC world's body.
AMitchell05 is offline   Reply With Quote
Old 03-02-2016, 09:58 AM   #18650
DennisNyholm's Avatar
From what I understand, you don't need anything. At least I haven't bought anything other than the aluminum front hinge pin holder and waterfall brace and fan. I use a finnisher body because I do have a waterfall brace and fan on my motor. Fits great.
DennisNyholm is offline   Reply With Quote
Old 03-02-2016, 10:18 AM   #18651
Silverstonev8's Avatar
I recently built a CE and used the lite instructions for the build. I found out that not included with the CE kit are the 1mm ball stud washers for the front camber link, shims for the outputs of the diff and the b5 rear arms. I think that was all.
I feel like the only plus about the CE kit is that it includes pretty shock bodies...
What made you pick up a CE for stock class?
Silverstonev8 is offline   Reply With Quote
Old 03-02-2016, 12:13 PM   #18652
Cridd's Avatar
My CE kit had the ball stud washers. You get the nice shock bodies but also the FT bearings.
Chris
B6D / T5M / SC5M
Old 03-02-2016, 12:15 PM   #18653
Cridd's Avatar
for sure. do think running a harder tire or insert in the front or at least same as rear is problably the best bet. I liked my 60mm dirtwebs, went to 2.2 which are ok, but think on indoor hard clay like the 60mm, going to try back to back.
Chris
B6D / T5M / SC5M
Old 03-02-2016, 12:34 PM   #18654
The spacers that came with mine were 2mm not 1mm. The lite comes with the FT bearings also
Old 03-02-2016, 04:30 PM   #18655
This car doesn't "NEED" any upgrades. I'm running the kit body. I'm also running 17.5 with this car. I chose this car over the lite because I'm racing on carpet and wanted the extra weight down low. I expected it to be a heavy, slow pig when I was done building it, but it came out weighing 1555. I'm happy with that!
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 03-02-2016, 05:59 PM   #18656
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Just got my Lite together... Waiting to get it on the track!!!
akura2 is offline   Reply With Quote
Old 03-02-2016, 06:03 PM   #18657
Love the chassis protector!
Old 03-02-2016, 06:27 PM   #18658
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
LOL where did you get that?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 03-02-2016, 08:13 PM   #18659
Looking good! What's the motor and esc setup?
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Just2much19 is offline   Reply With Quote
Old 03-02-2016, 08:18 PM   #18660
Trader Rating: 478 (100%+)
How about your diff? Is it possible that its a hair tight, worn out, built wrong? I just put a diff in one of my B5Ms and adjusted it too tight and my car was complete dog-sh-poop until I adjusted it accordingly.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
