    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 02-28-2016, 07:22 PM   #18586
Originally Posted by JC8390 View Post
What is the best thing to do on this car to pickup some easy rear grip?? My local track is clay and I notice sometimes towards the end of the day the high traffic areas of the track will get dusty and the car starts to kick out suddenly if you aren't really careful. I moved the rear camber link out on the hub which seemed to help...but it still breaks loose at times. And when it goes...it goes quick and stuff the nose right into a pipe before you can do a thing..no talking her out of it.
Running 17.5 turn motor, stock setup except for the rear link and I'm running the 3 gear transmission included in the champions edition. Running the same tires 90% of the guys at this track run...
Otherwise I've been really happy with the car.
Great suggestions so far. I would also try installing the B5 rear arms to get the rear hubs even farther forward. Remember.. Left arm goes on right side, right arm goes on left side of car.
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 02-28-2016, 07:37 PM   #18587
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Have you checked ride height?
One thing I know should help is
Batt position,
Rear hubs full forward,
More toe but avoid if you can
Buy the 3 x 1.4 pistons and run 27.5 oil with green springs.
You may want to rebuild front shocks too , maybe too much weight transfer.
JEFFs SC10 is offline   Reply With Quote
Old 02-28-2016, 08:22 PM   #18588
JC8390's Avatar
I'm going to move the hubs forward to see what that does and I'm going to have a softer rear spring on hand.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 02-28-2016, 08:22 PM   #18589
JC8390's Avatar
What is the best ride height on a clay track?
8ight E 4.0
RC10 B5M CE
Old 02-28-2016, 08:28 PM   #18590
tc5 man's Avatar
If your track is med grip with big jumps go with 23mm to 24mm . Most guys that run this buggy at my track run that . Me i liked 23mm better mostly cause he can drive harder , but 24mm will give you the more grip/body roll for the 3 gear .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 02-28-2016, 08:31 PM   #18591
It really depends on the layout and jumps of the track but at clubhouse here in MI which is med high smooth clay and layout changes all the time but usually I run 23-24mm. You don't want to bottom out but you also want to be as close to the ground as possible without bottoming out
Slashn77 is offline   Reply With Quote
Old 02-28-2016, 09:23 PM   #18592
Originally Posted by suzukipro View Post
I just bought one, but had to buy the gear-set, outdrives and housing separately.
Can you give me the parts numbers?
I saw 91462 91463 91465 but it looks like 4 screws are missing.
julieng is offline   Reply With Quote
Old 02-28-2016, 10:24 PM   #18593
Cridd's Avatar
Trader Rating: 16 (100%+)
[QUOTE=Socket;14409815]It took 10 years to get from the B4 to the B5 - and you guys think a B6 will come within 2 of the B5? /QUOTE]
No B6, only having fun, maybe hard to get the sarcasm in text.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-29-2016, 06:29 AM   #18594
I'm brand new to racing and having the same issues with the rear kicking out suddenly on my CE kit on indoor clay. I wasn't sure if it was the buggy or my driving, but other guys seem to be able to plant the rear coming out of corners much better than my car will. Watching this discussion with interest. I'll try moving my rear hubs forward and switching to 27.5 oil in the rear.
Gearhead82 is offline   Reply With Quote
Old 02-29-2016, 09:03 AM   #18595
I run the B5 rear arms w/ right side on left and left on right on mine as well and have the rear hubs forward.
I run a high bite clay track with not to many bumps or big jumps so i run my height at 19mm front and 18mm rear. Keeps me from getting traction rolls. Oil i run is 35 front and 32.5 rear with Blue springs front and green rear
youngrigo is offline   Reply With Quote
Old 02-29-2016, 10:03 AM   #18596
Trader Rating: 39 (100%+)
Interesting....what does swapping the arms do to handling?
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 02-29-2016, 10:07 AM   #18597
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You run the rear motor b5 rear arms and swap them. It moves the rear hub a few mm forward than the mid motor are capable of. This puts more weight over the rear axles. This is the stock setup on the lite kit and what most people are running from what ive seen.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-29-2016, 11:37 AM   #18598
JC8390's Avatar
Also... there is a totally separate thread but since we're talking about rear traction in here... im considering going back to the 4 gear, unless someone can really sell me on the 3. I mean there is a reason that's the box setup. I ran the 4 initialy and decided to try the 3 because I read it may make a stock motor a little quicker... but I noticed next to no difference.
8ight E 4.0
RC10 B5M CE
Old 02-29-2016, 11:38 AM   #18599
JC8390's Avatar
The only thing that makes me think... is I see like 90% of the associated guys at my track running the 3 gear...
8ight E 4.0
RC10 B5M CE
Old 02-29-2016, 11:48 AM   #18600
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
So you want to put the 4 gear in because of the box setup?......But you cant tell the difference anyway?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
