    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-06-2016, 06:30 PM   #18241
tc5 man's Avatar
3 gear mid motor on this buggy
Mod motor it is.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 02-06-2016, 06:32 PM   #18242
tc5 man's Avatar
Originally Posted by TC5Driven View Post
If your talking about the wing angle piece on the wing mount, yes I use that screw to tighten up the wing against the body clips that hold the wing onto the mount. It does give it a slight angle though.
I thought that was for so the wing holes don't crack actually.
Old 02-06-2016, 08:17 PM   #18243
The easiest thing you can do to solve it all is just cut those bumps off, drill and screw the wing down. You can either buy the Avid wing washers, I am sure J Concepts and everyone else has them too, or just use some washers that you have.
Just2much19 is offline   Reply With Quote
Old 02-06-2016, 08:22 PM   #18244
Just about finished up, I need to grab some battery foam.
Old 02-06-2016, 08:37 PM   #18245
Kudos I'm planning on using the exotek mounts one day when the stock one with the decal on the sides wear out
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 02-06-2016, 10:28 PM   #18246
I purchased a set of mounts from Shapeway that were lower than the stock. I had to trim the front of the wing so it cleared behind the shock tower. The lower front portion of the wing sits almost level with the dip in the shock tower. If I remember correctly the wing usually sits over the shock tower.
Old 02-07-2016, 05:15 AM   #18247
Hi
I've tried only two gear in my diff and everything works out nicely. But, I got a strange noise. Does it matter in which gear to remove in diff?
Does anybody have noise in diff when only try two gears?
Torvald is offline   Reply With Quote
Old 02-07-2016, 06:41 AM   #18248
MIP sells one with a replaceable insert (#15010), it comes with two inserts and you can buy more for $6 (#99099).
I've reused it before, I think another concern is the spring and replacing that too if you take it apart enough.
How often do you guys need to rebuild your diffs?
Has there been issues with the diff?
The MIP looks like some parts I want to have on hand so I will order some up but am wondering how the stock holds up?
RcJunky76 is offline   Reply With Quote
Old 02-07-2016, 06:47 AM   #18249
What your rig looks sweet. Can I ask what system your running? I'm sure you've told us but I can't remember and don't feel like searching back threw..
Old 02-07-2016, 11:14 AM   #18250
Thank you! Orion R10 and Trinity D4 17.5.
B5M CF, Orion R10, Fantom 17.5t FR1 Works Edition w/ M Stator & 12.5 Pro Select Rotor
DEX410V4, LRP SXX V2, Savox 6.5t
B4.1
SC10
Losi SCB
Old 02-07-2016, 11:19 AM   #18251
tc5 man's Avatar
Yea il do that sometime . But since i been staying on my wheels more with this buggy haven't had cracked the wing yet .
Old 02-07-2016, 07:56 PM   #18252
That's always my goal too!
B4.1
SC10
Losi SCB
Old 02-07-2016, 09:38 PM   #18253
Trader Rating: 483 (100%+)
Fellow user Socket suggested that I try using a quality tungsten ball and caged ceramic thrust. I went ahead and built several diffs that way and I have one that's coming up on a year old. I actually changed the outdrives but didn't even flip the rings. Still butter smooth. X rings and a caged thrust are must haves.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-08-2016, 08:45 AM   #18254
Yanks213x's Avatar
I actually snapped the diff screw by tightening it down to hard .. i was a little surprised because I felt like it had a lot of play. I rebuilt it and broke it in a little bit .. ran a few batteries through it as well. It'll be my second time on the track with it this week, should I tighten it up a little more ? What happens if it's too tight?
Yanks213x is offline   Reply With Quote
Old 02-08-2016, 08:54 AM   #18255
Do you have a link to those parts?
jneg is offline   Reply With Quote
