    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-05-2016, 01:44 PM   #18226
Volition's Avatar
With the wing shim, there's a boss for a screw across from the usual mounting points.
I assume they are for extra bracing. Does anyone use it? What's people opinions on using the extra screw boss? Would the screw need a washer too.
Volition is offline   Reply With Quote
Old 02-05-2016, 03:30 PM   #18227
TC5Driven's Avatar
If your talking about the wing angle piece on the wing mount, yes I use that screw to tighten up the wing against the body clips that hold the wing onto the mount. It does give it a slight angle though.
TC5Driven is offline   Reply With Quote
Old 02-05-2016, 03:46 PM   #18228
I screw my wing down and don't encounter any wing movement.
Just2much19 is offline   Reply With Quote
Old 02-05-2016, 03:48 PM   #18229
Originally Posted by Mason View Post
I'm not sure "borrow" is the proper term here. I have a feeling no diabetic really wants it back after you have used it.
Too freakin' funny! But on the other hand...
Speed Crazed Moron
born2build is offline   Reply With Quote
Old 02-05-2016, 03:51 PM   #18230
Volition's Avatar
Cool, in most photos I have ever noticed if people use it. I did a quick google image search on b5m's and did not see it in use. Makes sense though, the force through the wing both for downforce & for landing on its back (hah) is through that angle.
Old 02-05-2016, 03:57 PM   #18231
Too much typing, not enough racing. Just drive the damn thing!
Speed Crazed Moron
Old 02-05-2016, 04:33 PM   #18232
Originally Posted by RcJunky76 View Post
There nice packs and only took 3 days to get to me so am very happy.
I'm waiting to get everything together before I even attempt at wiring. Being my first buggy this is very tight and I want everything figured and in place before I tackle what at this point is looking like a cluster..lol
Oh and if you have the side foam in battery tray you will need to remove. The packs are tight side to side..
I needed the smaller battery for the LCG conversion. I read their website and everything in the lower 48 is 3 day fedex which is great!
I cant believe how small the battery is!
Old 02-05-2016, 07:13 PM   #18233
As I said I would I purchased a pack from Amazon and from Amain. The first thing that is obvious is the packaging, the one form Amain is shorter. This is not a mistake because I actually purchased two of these form Amain and they are both short. Also you cannot see it but one of their labels is just a little bit brighter. With all of this I am hoping this leads to a new batch that fits without fussing with it.
This weekend I will post more on how each fit.
I also got a package of parts, I am excited to finally finish this thing up and hit the track soon. I am hoping to be back on my feet within the next week or two.
Old 02-05-2016, 09:04 PM   #18234
Volition's Avatar
Aargh but what will I do when I'm not driving, spending money or wrenching!
Old 02-06-2016, 06:42 AM   #18235
I would think Amain sells more so I hope they have the newer sets but am interested in your find. Make sure to get pics of all your goodies so us that can't wrench can drool.
I have another 5 weeks before I'll be fully mobile but I hope I can atleast hop around in 1 more week..
RcJunky76 is offline   Reply With Quote
Old 02-06-2016, 06:56 AM   #18236
Trader Rating: 483 (100%+)
AE seems to change their packaging on stuff all the time. I have all sorts same parts with different labels and the same part #'s. I'm not sure that the parts are any different in most cases. You do have a stronger chance of getting different ballcups because those were definitely revised but I wouldn't bet on it.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-06-2016, 02:15 PM   #18237
Default ball diff bolt & t-nut
about to rebuild my diff and realized i do not have a fresh bolt a t-nut (part #ASC6575) - realize it's smart to use a fresh one every rebuild, but critical?
or is there away around buying a new one every time? thanks.
hsp-sandiego is offline   Reply With Quote
Old 02-06-2016, 02:21 PM   #18238
The Amain ones were perfect without any modification. I have an extra set if someone local wants to purchase them. I also change the balls studs to Lunsford titanium and JConcepts titanium turnbuckles.
I finally completed the rebuild and upgrade of the front and rear. I am waiting on new servo ends and a crimp tool to finally wire everything again. I located the transponder to just in front of the servo. I also have a new Orion R10 that I think I am going to try out instead of the Tekin RSX. Also sent Fantom an email inquiring about their FR-1.
Also changed the arms to the B5 flat arms front and rear along with all of the other parts in the photos.
I hope you get on your feet soon, I'm going through the same.
Old 02-06-2016, 02:26 PM   #18239
MIP sells one with a replaceable insert (#15010), it comes with two inserts and you can buy more for $6 (#99099).
I've reused it before, I think another concern is the spring and replacing that too if you take it apart enough.
Old 02-06-2016, 03:18 PM   #18240
yeah, those are sweet. thx
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
