    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 01-03-2014, 07:48 AM   #166
vito's Avatar
hows mid motor with a 17.5 be or is mid for mod racing
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 01-03-2014, 09:06 AM   #167
Default Gear diff ?
Is there someone that can tell if the B4 geardiff will fit ?
Jan F is offline   Reply With Quote
Old 01-03-2014, 09:24 AM   #168
OptimumRC's Avatar
Originally Posted by Adamska27 View Post
The key here is that the plates hit the gear when they broke in. I have experimented with less than designed diff balls many times, in an effort to reduce spring pressure but diffs need to be broken in to work with any real amount of torque. Running less balls (hehe, ok grown up again) is an oooolllldddd pan car trick and nothing weird. Sometimes the diff spring (even new) is too weak to spread across so many balls (in a smoothness losing move) run 2 or 3 less and remove evenly around. I've been known to pull 4 out of 14 or 16.
The new gearbox looks fantastic. They say stronger plastic, one of my complaints with the 3 - 4 platform. Carbide diff balls in the kit -- great call. Durango gives you aluminum balls in the kit and they melt with a 7.5.
I hope the rings are keyed -- I get annoyed with having to ca them.
The reason you dump your 4.2 is easy -- this car looks fantastic -- they claim to have fixed all the things that sucked and were antiquated. The insert thing is just plain easy and smart, and the 5 positions in the rear is a nice touch. Finally, a new gearbox and proper metric hardware. The new slipper was great, leave it alone, the new turnbuckles and ball ends look great, the old AE ones (and the RPM equiv) were long overdue for an overhaul.
I'm willing to replace arms often in exchange for less weight, however it was a bit out of hand with the 4.2.
I have to say, it looks like they hit this one out of the park
I don't know why you would want to CA your diff rings in place?
An additional function they provide is a 'safe' place for the diff to 'give' before slipping the diff balls. An example of this would be when losi went away from D-rings in their XXX platform and have continued the trend of all the other good diff makers like AE to use non-keyed diff rings. I could see how this would be different though for on-road.
OptimumRC is offline   Reply With Quote
Old 01-03-2014, 09:30 AM   #169
Pretty sure it won't because they've moved to metric.
lee111m is offline   Reply With Quote
Old 01-03-2014, 09:40 AM   #170
B4.1,2 Diff outdrives are already metric (10*16mm) I use it on a Bmax2 car thats all metric.
The idler gears could be bigger in dia? I know they were a weak Point on 4gear boxes.
But have they changed the diameter of the diffgear to ?
To race this on Astroturf you will need a geardiff for good lap-times (1 sek a lap) and a ball diff wont last a day on a high-grip astro track...
Old 01-03-2014, 09:43 AM   #171
Send a message via ICQ to JiuHaWong
The 22-4 uses keyed diff rings.
I've never used CA to hold my diff rings, but I always preferred that they were keyed.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 01-03-2014, 09:45 AM   #172
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The bearing size is only one part of it. The bones would need to be the same size also (not length). I am not sure anyone can answer that as of now. Someone said the new diff has the same amount of teeth, so it could definitely be possible if that is the case.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-03-2014, 09:46 AM   #173
were those diffs designed 15 years ago like most of the car j/k kinda.
Old 01-03-2014, 10:00 AM   #174
I really like the Associated diffs ,both the ball and the gear diff .
Old 01-03-2014, 10:00 AM   #175
Most pan cars use keyed diff rings.
Back on topic:
Is AE going to release any additional photos of the rear of the car, or the underside?
Old 01-03-2014, 10:11 AM   #176
Trader Rating: 120 (100%+)
I'm wondering too? Anyone?
B5M Lite Schuur Speed 17.5
T5M Schuur Speed 17.5
SC10.2FT Schuur Speed 13.5
Tekno EB48SL HW SCT Pro/Tekin 1900
Axial Yeti
jamr1130 is offline   Reply With Quote
Old 01-03-2014, 10:12 AM   #177
Jmuck69's Avatar
i understand that additional photos and a video will come out. A full product page will eventually come out.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-03-2014, 10:22 AM   #178
OptimumRC's Avatar
From what I recall, I think at the worlds the 22-4 had a lot of drivetrain issues, either slipper or diff issues. Regardless, the fact that their 2wd has non-keyed diff rings and the 4wd does just makes me think that they do not have the best idea on what they are doing in the diff department. I would look at diffs that have proven to do well and Kyosho and Associated certainly aren't keyed.
@Wildcat, I thought the same thing...lol
Bottom line, non-keyed diff rings are not bad, especially in off-road.
Old 01-03-2014, 10:25 AM   #179
That's why I asked about AE's use of the 14 ball diff. With the issues that TLR had initially, I'm unclear as to why they went to 14. Hopefully they figured it out.
Never said they were, just stated my preference for ones that are keyed.
Old 01-03-2014, 10:53 AM   #180
yep, I looked at the xx4 manual and they were keyed. My guess... tlr was lazy and just left it that way with no real reason, other than to save time and money.
