    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 01-20-2016, 02:12 PM   #17956
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Dal View Post
Hello everybody,
Does anyone know where to get, or what to use, for a 14mm rear wheel adaptor.
So I can use my 14mm hex rear wheels on this car?
Nothing is made specifically for the b5 to use 14mm hexes. You could always try and make something from a Durango or xray (or whomever else uses 14mm hexes). Unless you have a few pair of 14mm wheels you want to use I don't see any benefit. Nearly every wheel readily available in the US is 12mm hex
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-20-2016, 05:16 PM   #17957
i made a mistake and glued up a set of rear 2.4 tires on 2.2 wheels. will that make the car drive bad? should i just toss em or try them. trying to get ready for a big local club race friday and saturday
TJ9017 is offline   Reply With Quote
Old 01-20-2016, 06:28 PM   #17958
Jerm13's Avatar
Trader Rating: 36 (100%+)
Give the wife/ girlfriend/ mom $100 and tell her to go shopping.
After she leaves, heat the oven to 350-375*.
Turn oven off.
Throw them in there on a glass dish and wait 15-20 minutes ( make sure oven is off!!!)
Pull them out and peel the tires off.
Open all the windows and clear out the smell.
Get correct tires/rims and start over
(cheaper option)
Or... try them out and see if they work for you. Who knows
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 01-20-2016, 10:31 PM   #17959
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jstang50 View Post
I just purchased one of these kits and while installing the rear clamping 7mm hex on the upgraded axle I broke the bolt off in the hex. Is there a better aftermarket hex I can buy that will fit on the upgraded axle shaft? Thanks
I did same thing on first one then treated them with baby gloves. Been ok since then.
Anybody running roller pucks, MIP bones with stock outdrives? Any good?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-20-2016, 11:06 PM   #17960
Gpeters66's Avatar
I have seen many posts like this and they don't need to be that tight. You must realize that once the wheel is on there is absolutely no way it can fall off. I lost the screw on one one time and ran it like that forever with no problems.
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 01-20-2016, 11:08 PM   #17961
Gpeters66's Avatar
Originally Posted by Wildcat1971 View Post
The AE hexes are trash. JC needs to release theirs for the cars/trucks.
I have never had a problem with any of my AE hexes.....maybe it's the hexee and not the hexes?
Old 01-21-2016, 05:35 AM   #17962
thecman26's Avatar
Trader Rating: 98 (100%+)
Same here!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is online now   Reply With Quote
Old 01-21-2016, 07:18 AM   #17963
Bump stop tubing: I forgot to mention that the FL is set up in the manual using 5mm spacer shock spring cups on all 4 shocks. I used the 0mm spring cups and then added the 6mm front and 9mm rear fuel tubing. So no travel loss, just a restrictive compressive bumper. Does the same thing as an oring.
DeadstickDuck is offline   Reply With Quote
Old 01-21-2016, 07:35 AM   #17964
Trader Rating: 8 (90%+)
Turn oven off.
(cheaper option)
Or just use acetone...
juicy74 is offline   Reply With Quote
Old 01-21-2016, 07:42 AM   #17965
aeRayls's Avatar
Originally Posted by DeadstickDuck View Post
Bottom out bumper tubing: I forgot to mention that the FL is set up in the manual using 5mm spacer shock spring cups on all 4 shocks. I used the 0mm spring cups and then added the 6mm front and 9mm rear fuel tubing. So no travel loss, just a restrictive compressive bumper.
Ok so.... You don't lose travel no matter which spring cups you use. The different height spring cups are used for:
To use the springs on several different shock length. Example: 9mm cups for putting the springs on the truck and 0mm for getting a lower ride height with the stiffer springs like running on carpet.
By adding 6mm-9mm of fuel tubing outside of the shock, you 100% limited your up travel by that same amount! All of the sizes of spring cups sit in the same position on the shock eyelet at the same height. The cups only affect the spring and where it sits.
Example:
Using the kit recommended 5mm offset cup with the white front spring set at the desired ride height is the EXACT same thing as using the 0mm offset cup with the same spring but turning the threaded shock collar down 5mm. None of the spring cups effect the up travel or down travel of the shock shaft.
aeRayls is offline   Reply With Quote
Old 01-21-2016, 08:06 AM   #17966
Super Moderator
Example:
Old 01-21-2016, 08:13 AM   #17967
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by Matt Trimmings View Post
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-21-2016, 09:36 AM   #17968
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I elected to not really comment on the uptravel discussion, as I would not do this myself. at most I would use an oring or 2 if my bone were getting into my outdrives. But that has not been the case. So I see no need. And i definitely would not do it to keep my chassis from rubbing
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-21-2016, 09:46 AM   #17969
Jerm13's Avatar
If you are trying to save the tires and inserts...then no.
Old 01-21-2016, 02:55 PM   #17970
Volition's Avatar
3 questions for anyone who has tried the prime waterfall fan mounts ?
1. I’m going to use the WTF windy fan which is 16mm tall – I assume only the Finnisher body fits?
2. Has anyone tried a 10mm thick fan with the prime mount and got a silencer body on! Or does the extra 10mm get in the way.
3. If I want to cut the body I believe it’s illegal to cutout the body (unless the body has pre-marked air inlet marks) is that correct?
Volition is offline   Reply With Quote
