    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 01-19-2016, 02:50 PM   #17926
What affect would leaving out the droop limiters have when building the shocks?
65BAJA is offline   Reply With Quote
Old 01-19-2016, 04:58 PM   #17927
More (less droop /downtravel): The car changes direction faster,and corners flatter. It feels generally more responsive. Adding a lot of travel limiters is only advisable on smooth tracks.
Less (more droop /downtravel): Less internal shock spacers give better handling on bumpy tracks,and more and more consistent traction on difficult tracks. The car also land better after jumps.
The end with the least downtravel will feel the most stable,and the most direct. But try to keep a balance (front and rear end droop about the same). especially on low-grip tracks.
Adding more internal travel limiters is a very effective way of reducing traction rolls,if not the most effective way.
http://site.petitrc.com/reglages/BuggySetupGuide.pdf
shdwboxn is offline   Reply With Quote
Old 01-19-2016, 08:48 PM   #17928
duckhead's Avatar
Originally Posted by Jerm13 View Post
2 inch. Unless you are running an extremely long link, then use a 2.1".
The FL kit comes with 1 7/8" blue titanium turnbuckles. I ordered a Lunsford kit and for whatever reason the links are shorter, and I bent two of them in the same spot (left rear). I went ahead and ordered 1 7/8" links from Lunsford's site and have been good since. 2-2.1" might be pushing it a bit unless you are running real long links.
duckhead is offline   Reply With Quote
Old 01-19-2016, 09:13 PM   #17929
duckhead's Avatar
Originally Posted by Scargoes View Post
I've had high end Orion and Futaba servos go out on me. Last one was the Orion and it went out on the second race night. All of my Savox servos have been reliable.
I've had good luck with the Savox 1273TG servo and it is under $100. My only issue with Savox servos is they tend to be a bit on the loud side.
Old 01-19-2016, 09:24 PM   #17930
B5M FL 17.5T high grip carpet:
I broke a blue titanium front caster turnbuckle on my B5M FL today on only it's 2nd pack run in the car.
IMHO my car was the only one landing smoothly like a cat this afternoon with 1/4in front and 5/16in rear silicone tubing bottoming out bumpers. Just slice down the side of the tubing, pull up the spring and slip it around the shock shaft, zip tie around the piece so it stays on the shaft and not deform and slip off. Easy to remove if you don't like it. Basically free.
As for shock tower taking all the force...isn't it anyway? When the car bottoms out all the force hits the dead stop...aka the bottom cap of the shock and spring retainer/turnbuckle..... Yes the shock absorber dampens it for most of the energy transfer, but equal force is applied to the shock tower. What is better, a hard thump into dead stop or travel limit screws, or a squishy bumper that keeps the chassis about 1/8in in off the deck when it bottoms out? My 2 cents for high grip carpet and "sauce".
Well...actually I suppose the bottom of the car slaps the ground and takes the force, the shocks still have some travel in them.
DeadstickDuck is offline   Reply With Quote
Old 01-19-2016, 09:28 PM   #17931
duckhead's Avatar
Originally Posted by hsp-sandiego View Post
the Savox 1257tg is the one you want - direct from Savox, is $60 shipped and they ship quick! I just posted about using the Losi horn as well - like it's made for this kit. 25T is what you want for a Savox servo. with the 1257tg, there is just enough space to "back and forth" the servo wire behind the servo and tuck in for a clean install. 1257 vs 1258 - the 1257 is faster, 1258 more torque.
The Losi horn is threaded standard - I just drilled the threads out a bit then tapped with a metric screw / 2mm - same size as the steering ball stud... or use a tap if you have it.
hope that helps.
Another option for an aluminum servo horn is: http://www.exotekracing.com/ae-heavy...orn-7075-f-25/
Fits great in the B5M and is already threaded for the metric ball studs.
Old 01-19-2016, 09:29 PM   #17932
Trader Rating: 15 (100%+)
For those of you who sauce your tires...
Do you apply it to the Rears Only? or Front and Rear?
motoman811 is offline   Reply With Quote
Old 01-19-2016, 10:02 PM   #17933
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Torvald View Post
Can someone explaine the bold part in my quote, did not get it.
Never heard before. Sound a little cra cra.
Use X rings on your shock build is the norm and adjust package to reflect the amount of travel. That post feels like a slam on AE more then a helpful post.
Kody N. has posted some good shock package info on Facebook, may want to take a look.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-19-2016, 10:07 PM   #17934
Full rears and inside-half on the fronts @3~5 minutes before you power up. "Not sure if it's a trade secret but anyone doing it right will not be slamming into mine or anyone else's car as often and competition makes you a better driver. Control is a lot safer than out-of-control...
Or is it. Out-of-control is faster than slower in-control?
Old 01-19-2016, 10:13 PM   #17935
Cridd's Avatar
All tires all over. Enough time for them to dry just before track time is what I have been to,d.
Chris
B6D / T5M / SC5M
Old 01-20-2016, 05:38 AM   #17936
Jouster's Avatar
Does anyone have any idea when the B5M Lite will be back in stock at AE?? It's been unavailable for months.
Jouster is offline   Reply With Quote
Old 01-20-2016, 05:57 AM   #17937
DennisNyholm's Avatar
Tower says February. Good thing I ordered when I did. Seems everyone is out. 2 stores by me have a CE kit in Stock each but that is it
DennisNyholm is offline   Reply With Quote
Old 01-20-2016, 07:00 AM   #17938
Super Moderator
Trader Rating: 17 (100%+)
How bad ya want one. I'm not running mine right now and it has Pucks and Aura Ceramics in the trans
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-20-2016, 07:12 AM   #17939
Originally Posted by lee111m View Post
I don't know why you would limit the shock that way. If you land crooked you'd want that extra travel. If you think your chassis is slapping way to much you should change your shock package instead of limiting it more.
The idea isn't really limiting travel, it only leaves 1 mm of lost travel. What it does is keep the chassis from dragging on the ground and scrubbing speed. On clay it will also reduce the amount of clay packed into the transmission mounting screw heads.
Eddie_E is offline   Reply With Quote
Old 01-20-2016, 07:26 AM   #17940
tobamiester's Avatar
Trader Rating: 274 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
GP shows 2/15 for availability.
tobamiester is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
joesiv
