Team Associated RC10 B5m Mid-Motor Thread
Thank you for the replies about the diff oil!
2k/3k, very flowing high grip 5k
It probably won't be an issue other than the body might hit it.
Looking around at all the other cars, I see the capacitors mounted to the chassis. So if you have room on the chassis target that area first. Just make sure that the shrink wrap around the capacitors is in tact because you don't want it to short out on something metal.
Ce kit
I find it odd that the CE kit comes with both ti and steel turnbuckles. Why did they bother including stainless turnbuckles?
http://m.homedepot.com/p/Ryobi-4-Vol...P54L/205545276
I'm of the honest opinion that the rear b hub "half hole longer" link position should be the default on this platform, regardless of the height of the inside ball stud position specific to your track. I think it makes the car rotate more linearly on most layouts and have a bit more traction when starting out. I really like it.
On the standard plastic rear hubs there are 2 pill options. Kit built is 3 hole with link mounted to center hole. The other option is a 2 hole pill which is essentially the locations you cant hit with the 3 hole. This was a change i made on the first day i had my kit on the track and have only considered going back to center hole when the car gets tight.
Not sure which location roughly matches this in aluminum hubs.
Trader Rating: 53 (100%+)
Where should I start for pinion size? B5M Lite on medium size, medium bite indoor track with 9.5 motor 81 spur? Thanks
Dropping my PlanB/ACRC stock buggy in here. I'm excited to see how well this will do after more time getting used to it.
R/C Tech Elite Member
FWIW, At my local med sized & med bite indoor track I run a Reedy 9.5 geared 29/78 with 30° on the can and nothing in the ESC
Sorry I meant to write 24 and 81. Since you wrote for a 81 spur.
