    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-12-2016, 05:32 AM   #17746
WonTonsChicken's Avatar
Trader Rating: 42 (100%+)
Originally Posted by tc5 man View Post
Ok i just ordered one not a fan of the ball diff still.
2k diff fluid definately for Bumps!
--Special Thanks to--
Tekno RC - Pro-Line - Boca Bearings - Team Tekin - FTM Grip - G's RC Raceway - CowRC!
Tekno ET48 | NB48 | EB48.2 | SCT410 | AE B5M | Pro-2 SC
WonTonsChicken is online now   Reply With Quote
Old 01-12-2016, 07:33 AM   #17747
BRSracing's Avatar
Trader Rating: 53 (100%+)
Originally Posted by MadMaxima99 View Post
Trying to fit a servo into this chassis has been fun. Finally got a Savox 1252 in there, but it still hit the case on the way down. I went ahead and used my knife on the plastic of the tie rod to gain some clearance.
The only servo i had issue with was a short servo. if your having issues it maybe a install issue.
BRSracing is offline   Reply With Quote
Old 01-12-2016, 07:52 AM   #17748
Trader Rating: 140 (100%+)
Originally Posted by man1ac View Post
I just rechecked my pinion/spur mesh on my B5, SC5m and a collagues B5m and we noticed the clearnce between both isnt quite constant. Since the motor has quite a good concentricity it must be something on the spur gears side (spur gear? top shaft? bearings?).
Due to all 3 vehicles have this problem it's ahrt to set the gear mesh correctly. Any suggestions on how to get a nice, constant gear mesh that does not result in noisy cars?
recently discovering similar issues, not just on ae cars
check your pinions
not all pinion gears are alike, some noisy gear meshes are a result of pinions,
they do ware, and depending on brand , make a different sound
try a different brand , new pinion, along with new spur and proper mesh
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 01-12-2016, 09:36 AM   #17749
Trying a different brand will be quite annoying, due to I bought a whole set of robitronic and changing the brand altogether would cost arou 100$ (just for the sound)
I rechecked everything and its way better now...I'll live with that for now (neither pinion nor gear looked worn or damaged, so I cant be that wrong)
man1ac is offline   Reply With Quote
Old 01-12-2016, 10:10 AM   #17750
Mason's Avatar
poor boy solution: Spin the gears a 1/4 turn and check the mesh at each location. Adjust spacing accordingly.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-12-2016, 10:28 AM   #17751
boborc's Avatar
Just got a b5m fl and was wondering with the 3 gear trans do i need to have the motor run in reverse direction. I dont think the esc I'm going to use has the reverse option ( a novak havoc pro with supertuner upgrade)
boborc is offline   Reply With Quote
Old 01-12-2016, 10:29 AM   #17752
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
No. The motor is mounted opposite from the 4 gear.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-12-2016, 10:40 AM   #17753
boborc's Avatar
Thank you very much, didnt even look at that
Old 01-12-2016, 01:03 PM   #17754
I have a few servos I was trying(Spektrum S6070, an couple of older futabs, hell even a stock traxxis slash servo) and they all seemed to have the same issue.
If you put the stock spacer(little blue aluminum spacer) on the plastic horn supplied with the kit, it will hit as the horn moves down towards the servo. All the servos seemed to have a flat top.
The Savox 1252 looks to have a curve on the top that helps the tie rod move close to all the way if you remove the blue spacer. i still had to modify where the servo wires came out. But that's because this chassis wasn't made for low profile servos. It looks like it was made to use an inbetween size.
I was actually looking at a set of HPI horns at my LHS. They look to have more clearance than the stock AE ones.
I will take some pics and post them tonight. Maybe I am doing something wrong.
MadMaxima99 is offline   Reply With Quote
Old 01-12-2016, 01:07 PM   #17755
tc5 man's Avatar
Ok wouldn't that diff out easier though ? I was thinking 3k or 4k .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 01-12-2016, 01:34 PM   #17756
You could try, but I was at 5k.. I though that was pretty smooth, but the 2k was right on. Never hurt to try though
Old 01-12-2016, 01:48 PM   #17757
Had no real issues using a TS-920 servo and correct to 2s.
DeadstickDuck is offline   Reply With Quote
Old 01-12-2016, 02:07 PM   #17758
tsair's Avatar
IIRC, most people don't generally use the blue spacer.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 01-12-2016, 03:17 PM   #17759
tc5 man's Avatar
Do you still use the Blue spacer on full size servos ? Actually i don't know what its for .
Old 01-12-2016, 03:33 PM   #17760
Does anyone run the xp servo from AE? Would be nice to see a side by side say to a savox 1252 or 1258. The AE servo looks to have a step up where the horn mounts to. Providing more clearance for the tie rod to clear the servo case.
