    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-23-2015, 04:20 PM   #17371
JBR18's Avatar
True newbe question have the stock/book setup on and won't turn, till it really slows down. Running indoor,packed clay.have j concept barflys on rear proline scrubs on front. White w/30 wt in front green w/27.5 in rear.
JBR18 is offline   Reply With Quote
Old 12-23-2015, 04:46 PM   #17372
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Imo 2800 mah would be too little for our current layout. I see no reason to go lighter than a normal shorty
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-23-2015, 05:51 PM   #17373
Trader Rating: 18 (100%+)
I run the lcg shorty. 3500 to 3900 may depending on the manufacturer. About 150 grams versus 210-220 for a normal shorty. Works great.
Chris Brown is offline   Reply With Quote
Old 12-23-2015, 06:53 PM   #17374
a1
Originally Posted by Chris Brown View Post
You just need the motor plate, gear cover,four gear transmission case, idler gear, bearings, and idler gear shaft. They don't sell an all in one kit.
Originally Posted by Dray01 View Post
1x 91552 V2 4 gear Trans case
1x 91428 Std motor plate or 91546 LW Blk plate or 91547 LW Blue Plate
1x 91435 gear cover
1x 91429 Idler gear
1x 91011 Idler shaft
2x your favorite variety of 5x10 bearings
BD
thanks again guys . Everything went together with no problems at all. Took about 20 -30 minutes. Now I have a 4 gear transmission and it was a lot simpler to do that I originally thought.
a1 is offline   Reply With Quote
Old 12-23-2015, 06:59 PM   #17375
hello all just curious how the car would be with no shock limiters? im using 2 and 2 but trying to get more weight transfer to the rear would this help?
DIRT DIGGER is offline   Reply With Quote
Old 12-23-2015, 09:26 PM   #17376
tc5 man's Avatar
Well while putting together my B5M i noticed that i got the wrong top shaft in the transmission its the Associated alum top shaft for the 3 gear . So what is the difference will it work with the 4 gear ?
I have the V2 gear boxes .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 12-23-2015, 09:59 PM   #17377
BLKXJ96's Avatar
I'm pretty sure all the newer kits come with the light weight top shaft now. So if you want to switch to three gear you're that much further ahead.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 12-24-2015, 07:01 AM   #17378
Kalio's Avatar
Does anyone have any recommendations for choosing which aluminum wing mount to go with? Seems like there are so many choices but none of the manufacturers or stores list weight. The only reason I even want one is to use the wing buttons instead of clips to save on wear and tear. I'm leaning towards the Exotek one since it "looks" the most lightweight and has different button color options but it's also the most expensive.
Kalio is offline   Reply With Quote
Old 12-24-2015, 07:41 AM   #17379
Jmuck69's Avatar
No need for aluminum. Cut the buttons flush with a dremel and then drill holes for 3mm screws and done.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-24-2015, 07:45 AM   #17380
Kalio's Avatar
Hmm, interesting idea. That would save weight and money. I might try that. Thanks!
Old 12-24-2015, 07:51 AM   #17381
Remove 1 mm from the front ackerman, battery forward, 1.4-3 shock piston w/32wt oil up front (or 1.7-2 with 35wt)up front and M4 electron fronts.
Eddie_E is offline   Reply With Quote
Old 12-24-2015, 08:27 AM   #17382
dirt42fan's Avatar
Trader Rating: 135 (100%+)
I just got a low profile Savox SC-1252mg servo and went to install it and noticed that the wire is right where the servo mount screws to the chassis.
Any recommendations for this? Or do I just mount it up and forget about it?
Thanks and Merry Christmas!!
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 12-24-2015, 08:30 AM   #17383
Cridd's Avatar
Trader Rating: 16 (100%+)
I'm using the low pro from redshop on shapeways, light and work good.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-24-2015, 10:17 AM   #17384
1/4milecrazy's Avatar
I removed the rubber grommet from the wires and then ground off the corner of the servo mount with a Dremel. Never had a problem, I have done this on many 5 series vehicles for others who are running smaller servos.
1/4milecrazy is offline   Reply With Quote
Old 12-24-2015, 10:55 AM   #17385
Just finished my build. Work flawlessly! Altough I have to admin, every bag seemed to be labelled wrong. The manual sag (e.g.) Bag G and it was H (always one letter ahead/behind). Just installed the electronics (Nosram HD, 8.5T Sonic M2) and damn, that thing is fast
But the most depressing part still ahead: Thinking of a good style/painting and trying to paint that
Anyone ideas of a style with neon green/gunmetal (and third color? white? silver? red? metallic blue?)?
man1ac is offline   Reply With Quote
