    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-21-2015, 04:13 PM   #17341
dirtdog's Avatar
Trader Rating: 20 (100%+)
Anyone running machined pistons 3 hole 1.4 32.5 weight up front and 2 hole 1.6 30 wt in rear on high bite clay? Worn dirtwebs work well on are track.. Im struggling to find speed with the car. I see that some people are switching the pistons the opposite way i have them. Balance is not terrible...
Tim Christensen
Agama
Beta
95zero
dirtdog is offline   Reply With Quote
Old 12-21-2015, 04:14 PM   #17342
dirtdog's Avatar
Rest of the setup is factory lite.
Tim Christensen
Agama
Beta
95zero
Old 12-21-2015, 05:04 PM   #17343
mblgjr's Avatar
Trader Rating: 86 (100%+)
Yes I have. 3x1.4 have less pack but respond quickly to fluid changes.
Try 35wt 3x1.4 & 32.5wt with 1.6flat and youll find a similar feel.
Unless in low grip I dont like 3x1.4 in the rear
mblgjr is offline   Reply With Quote
Old 12-21-2015, 05:24 PM   #17344
mick33b4's Avatar
Originally Posted by QDRHRSE View Post
I also think that one of the other posters has misinterpreted roll center. Roll center is all about the angle of the link. In most cases if you lower the inside you'd be lowering the roll center by reducing the angle of the rear link. we can argue about it all day but roll center is really all about the link angle....a longer link, more roll, reduces the angle of the link....more traction longer link. Less traction, shorter link, typically steeper link angle, higher roll center. Maybe I have it backwards, but I doubt it, regardless....I'm willing put myself out there for everyone to criticize.
No criticism necessary. Always a good debate.
Lower inner link, in the case of the B5, in fact raises the roll center. But, you are absolutely correct about roll center being controlled by the link angle. I always think of longer links making an impact toward lower camber gain, and slower change of the roll center through the suspension motion. RC Crew Chief is a much better expert than me as to the relative differences (inner link vs link length).
Whenever I get lost, I always refer back to these posts. Have never let me down.
Understanding and Tuning Roll Center
The "OFFICIAL" Camber Link/Roll Center Debate Thread
"Razathorn" in fact chimes in on this B5M thread (Official Team Associated RC10 B5m Mid-Motor Thread) stating how he likes the 1/2 hole longer rear link position. Says it's more stable, and gives a more linear rotation feel.
EDIT: Much better discussion than I've provided (B5M specific) here:
mick33b4 is offline   Reply With Quote
Old 12-21-2015, 05:29 PM   #17345
dirtdog's Avatar
So stay with my current setup and just go up in oil?
Tim Christensen
Agama
Beta
95zero
Old 12-21-2015, 05:45 PM   #17346
mblgjr's Avatar
Try it first.
What are you looking for or wanting the car to do?
Old 12-21-2015, 05:48 PM   #17347
Originally Posted by monty c View Post
don't know if this has been asked but quick question, building the new CE kit, they say run the rear motor rear arms on the setup sheet but they arent included in the kit? is this correct?? the kits only comes with the regular MM arms, both sets of front arms are included but not the RM rear arms.
The CE comes with MM rear arms. At least mine did. If the kit included the RM rear arms there would have been a mention of this in the included supplement manual. They should have been included in the kit though, because it's shown in the recommended set-up sheet. It also comes with a Factory Lite decal sheet? Weird...
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 12-21-2015, 06:12 PM   #17348
dirtdog's Avatar
Try it first.
Its pretty neutral. Feels a little edgy on corner exit. Pushes like a 2wd buggy on power. Just having a hard time getting the power down as fast as others.
Tim Christensen
Agama
Beta
95zero
Old 12-21-2015, 06:27 PM   #17349
mblgjr's Avatar
Try 3mm trail with standard ackerman.
Use long rear link, stock hubs 2hole inserts using the outer hole. If youre running aftermarket hubs run anextra 0.5mm under the stud.
Measuring between the shoulders of ball cups should be approx 27mm iirc
Old 12-21-2015, 09:49 PM   #17350
Cridd's Avatar
Trader Rating: 16 (100%+)
Mine came with mm arms too, weird. didnt even think that they were not rm arms.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-22-2015, 05:52 AM   #17351
Gpeters66's Avatar
Originally Posted by twisted View Post
anyone run one of the raptor bodies?
http://wildebeestdesigns.com/bfgrc/i...&products_id=3
I wish I had seen this body before I bought my last one...gonna have to get one of these
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 12-22-2015, 05:55 AM   #17352
So the reason people are switching the pistons is because of the way the 3 gear works, it levels out the chassis while driving so it actually makes the rear end ride higher then with a 4 gear which is why people are wanting 3 hole in tha back for more traction and 2 hole in the front to tame down the steering.
Mxer210 is offline   Reply With Quote
Old 12-22-2015, 07:20 AM   #17353
Trader Rating: 68 (100%+)
Installed one if my 3gear lcg trans cases in my sons car for more testing.
He decided he wanted it blue, so we did a quick rattle can job on it before installing.
-Dave
Race: B64D / B6D / B6
Coming Soon: Tekno EB410?
Pinebox is offline   Reply With Quote
Old 12-22-2015, 07:54 AM   #17354
WonTonsChicken's Avatar
Trader Rating: 42 (100%+)
Now, THAT is cool! well done!
--Special Thanks to--
Tekno RC - Pro-Line - Boca Bearings - Team Tekin - FTM Grip - G's RC Raceway - CowRC!
Tekno ET48 | NB48 | EB48.2 | SCT410 | AE B5M | Pro-2 SC
WonTonsChicken is offline   Reply With Quote
Old 12-22-2015, 12:49 PM   #17355
I'm going to try for a lower ride height setup for super high grip office carpet this week. Has anybody found a good roll center setup for ride heights around 16 mm? I assume that The 1/2 hole longer at the rear hub would be the right direction and I'm thinking about going up to the +2 position on the inside rear ball stud and adding 3mm limiters in the shocks.
I am running 18 mm ride height with stock shock limiters and I have been struggling with traction roll at the end of the straight. The Yokomo's with low ride height turn right inside of me and carry more corner speed.
Eddie_E is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
