    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 03-07-2014, 12:21 PM   #1711
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
For you 17.5 guys....Aluminum top shafts are in stock at AE.
http://www.teamassociated.com/parts/details/91427/
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-07-2014, 12:35 PM   #1712
Originally Posted by Mason View Post
fancy wiring just means you'll miss a race trying to fix/replace something. been there, done that. stick with the KISS method.
Point taken, you are a tough crowd! Anyway, measured up the chassis and there is about 1,0mm wall thickness in the sensor cable recess so not much to act on there….even using a 14awg cable would have to raise the battery quite a lot...
B5M
22 2.0
B44.2
TC4
SC10 4x4
Pellefa is offline   Reply With Quote
Old 03-07-2014, 12:47 PM   #1713
proraptor's Avatar
Update
Got my package from AE. They sent me a coupl shock collars and they screwed on just fine so it was the shock collar that came in the kit with the messed up threading.
B5M, Tekin RS pro with Tekin redline gen 2 8.5, Savox 1258TG
savage flux 2350, 7950th
Airtronics Mt4
proraptor is offline   Reply With Quote
Old 03-07-2014, 01:22 PM   #1714
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
great news.
Love the avatar, one of my favorite movies and the commentary at the menu screens is hilarious.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 03-07-2014, 01:26 PM   #1715
Originally Posted by TomErickson View Post
Not a dumb question. I use it where screws are threaded into aluminum parts. Also the manual should indicate where thread locker should be used. I use AE Blue thread locker. Blue Loctite works well. Don't use Red loctite.
"Should" being the keyword there. The manual should indicate where to use loctite but I don't recall my B5M manual mentioning locktite at all. I always do the same thing too...locktite on screws that go into any metal components.
Tekno EB48.4
Tekno SCT410
Associated B5M 17.5
Associated SC5M
JPM398 is offline   Reply With Quote
Old 03-07-2014, 01:35 PM   #1716
Just got mine built yesterday. Dang this car is nice! (coming from a B4.2) As others have said, the fit is perfect and the plastics seem more solid now. Hearing about other guys having missing parts, bad machining, etc.. I was a little worried going into the build, but turns out I was one of the fortunate ones to have a complete kit that didn't require me having to contact AE.
Can't wait to get this thing out on the track!
Tekno EB48.4
Tekno SCT410
Associated B5M 17.5
Associated SC5M
Old 03-07-2014, 01:47 PM   #1717
kingy1's Avatar
So to save wading through ~1700 posts of bickering, speculation and eventually a few photos to finally get to the rare tip, does someone want to kindly fill me in on some build tips and things to look out for? I'm seeing a few posts about shock shaft diameter, a few missing screws and front bearing being crushed? Expecting mine to arrive in the next couple days.
Would be great if the op could be updated with essential information (which is what I thought the whole point of it was)
Associated [RC10B5M - RC10T4.1 FT - RC10B4.1 WORLD'S - RC10B44.2 - RC8T CE-E - RC8BE]
Durango [DESC210R] Ofna [NEXX10SC]
RC4WD [Bully] Gmade [Sawback] Axial [Scx10 - Wraith - Yeti] Eagle Racing [R31]
kingy1 is offline   Reply With Quote
Old 03-07-2014, 01:58 PM   #1718
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
ok, here it is. The ball cups are painful for many. Chapstick/grease and open up the bore for the turnbuckles. I think its a 7/64, but you will wanna verify. Some people are shimming the rear arms because they are sloppy. Most people are not sloppy. Get the clamping front hexes or use locktite on the front axles to keep them from falling off. the bearings suck, replace now or when they are trash.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-07-2014, 02:16 PM   #1719
kingy1's Avatar
cheers for the update. Was planning on using factory team b4 turnbuckles, last I heard they are compatible, right? Grease on the turnbuckles when building is always a nice thing to do.
get the clamping front hexes, or get some clamping front hexes? I've got some avid clamping 12mm hexes floating about for an sc10, will they do the trick?
Still need to get around to ordering an avid bearing kit, was hoping to get a few meets out of the stock ones first.
Old 03-07-2014, 02:21 PM   #1720
Super Moderator
I would get "the" clamping front hexes. Will "some" clamping hexes work? Maybe. Will they be the wrong offset? Most likely.
Old 03-07-2014, 02:27 PM   #1721
I dont think the B4/sc10 front axles will work. Can you get the avid hexes to work on the new B5 front hex axles.....Maybe. The B4 rears "fit".
Old 03-07-2014, 02:30 PM   #1722
kingy1's Avatar
That's why I'm asking. I assume this is the part you are referring to?
http://www.teamassociated.com/parts/details/91409/
they are quite slim, but in a pinch I could just grind the avid ones down to fit
http://www.avidrc.com/product/5/acce...cessories.html
Old 03-07-2014, 02:31 PM   #1723
Super Moderator
SC10 rears are considerably wider than the front B5 clamping hexes, just use the stock setup and loctite the screw in. A little goes a long way.
Old 03-07-2014, 02:33 PM   #1724
I would not even mess with grinding those. The stock front hexes are fine, just use blue loctite and let it set. And maybe reapply and let it set again.
Old 03-07-2014, 02:35 PM   #1725
Super Moderator
Once will suffice
