    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-10-2015, 07:00 PM   #17206
Hey guys I just ordered a b5m to race on carpet at my lhs, I currently race sct there with my son. We run the castle sct combo 1410 motor 3800 kv and have had great luck with them, I was wondering if anybody here has run this combo in this buggy. I am leaning towards this because of our experience we have had and I already have the programmer to tune it as well. Being somewhat new to the hobby I wanted to get some input to see if this would be too much for the lighter chassis of the buggy and cause difficulty driving due to excessive power. I would really like to spend $120 max for a motor esc combo if anyone has any other suggestions. My lhs is the only place we race and I only do this for fun on Friday nights so I am not looking for a high end pro setup, just something that's reliable like we already have in our sc trucks. Thank you for any input.
Ghk700 is offline   Reply With Quote
Old 12-10-2015, 07:35 PM   #17207
a1
anyone have a good setup for a mid traction dirt track to get me started? The track is bumpy and rutted with large jumps.
a1 is offline   Reply With Quote
Old 12-10-2015, 07:53 PM   #17208
Jerm13's Avatar
Trader Rating: 36 (100%+)
I would stick with what you already know and have had success with. No point in re-learning. Keep the motor in the 3800-4300KV range and you are good. Unless you are going to be running a "stoc" or spec class. Then get the motor according to the rules. Good luck.
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 12-10-2015, 07:55 PM   #17209
Jerm13's Avatar
The kit set-up is a pretty good starting point. Maybe a little softer on the shock oils, say 2.5-5 wt, and adjust from there. I have found it to be a pretty neutral set-up. Not a lot of push in the front, or loose rear end...
Old 12-10-2015, 10:58 PM   #17210
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Does the CE kit come with machined V2 pistons or chrome V2 shock shafts?
pink_sleeve is offline   Reply With Quote
Old 12-10-2015, 11:07 PM   #17211
I'm sure this has been talked about before but I'm unable to locate it. Has or does anyone use the MIP 3gear aluminum trans? I run stock and wondering if it's worth it. I can get one for about $30 new so I think it's a pretty good deal. I just don't want to have any adverse effects on my car.
Polock is offline   Reply With Quote
Old 12-11-2015, 06:43 AM   #17212
Cridd's Avatar
Trader Rating: 16 (100%+)
I'm pretty sure no V2 pistons and shafts, just Kashima shocks
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-11-2015, 06:43 AM   #17213
Cridd's Avatar
30 bucks is a good deal, I have not heard anything bad about it other then cost.
Chris
B6D / T5M / SC5M
Old 12-11-2015, 06:52 AM   #17214
Default GEAR DIFF
Found it. Did a search.
retat is offline   Reply With Quote
Old 12-11-2015, 07:16 AM   #17215
Default B5m or B5m lite for mod motors?
Currently running a Centro c4.2 and getting back to the track (indoor clay) - looking at a new ride. b5m or b5m lite for running mod motors? main question relates to the 3 gear trans, no so much weight. Does the 3 gear trans still work well in the air?...brake to fly wing high. As I understand, with 3 gear, less force is put on the front of the car during braking, more on acceleration - I could have this backwards.
thanks.
hsp-sandiego is offline   Reply With Quote
Old 12-11-2015, 07:20 AM   #17216
speed passion revention pro. or check used / classifieds here for something. the Viper stuff is very good and very little soldering needed (motor only) - easy to program with the card and smooth.
Old 12-11-2015, 07:21 AM   #17217
speed passion revention pro combo - check ebay. or check used / classifieds here for something. the Viper stuff is very good and very little soldering needed (motor only) - easy to program with the card and smooth.
Old 12-11-2015, 08:01 AM   #17218
thecman26's Avatar
Trader Rating: 99 (100%+)
I found a good deal, Trackstar 120a esc and Trackstar motor, $95 with programming box! Not bad huh? Heard pretty good things about them. Jason Snyder did a video on the esc and programming box.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 12-11-2015, 08:02 AM   #17219
EricW's Avatar
thanks.
If you go to the AE website they list the B5M as being discontinued and the CE version is considered a limited release so I would assume the lite will be the go to car for both mod and stock.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 12-11-2015, 11:05 AM   #17220
I run FE Boats and run the Turnigy ESCs the T180 and they are pretty much the standard we use at the boat pond - very solid, reliable with good performance, simple program card.
