    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-10-2015, 09:45 AM   #17191
Trader Rating: 49 (100%+)
Originally Posted by DIRT DIGGER View Post
If I use the 3.5mm toe in with the c mount can I still have the arrows in on the d mount?
yes, you never change that
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-10-2015, 09:47 AM   #17192
JayL's Avatar
Originally Posted by touringdriver View Post
Well the V2 case did not fix issue. Can anyone shed a light on this issue? A friend said there was a running parts change but I can't find any part numbers. Almost ready to sell this thing and find another brand.
By 'upper shaft' do you mean the topshaft? My topshaft only has two bearings and they are 5x10x4, 91560
the old gear case case had smaller bearings the new cases have 5x10x4
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 12-10-2015, 10:07 AM   #17193
Jmuck69's Avatar
Old case had 6x12 bearings.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-10-2015, 11:44 AM   #17194
JayL's Avatar
ya that, duh..Don't know why I was thinking smaller, that would almost be inpossible
Old 12-10-2015, 12:23 PM   #17195
Jmuck69's Avatar
could be the bearings from the steering rack....
B6D | B64D
Old 12-10-2015, 03:08 PM   #17196
Trader Rating: 36 (100%+)
Just got a used b5m that I got off here and noticed that it has the trailing inserts glued in at the 2mm position. Does anyone run theirs like this. All my other 5m vehicles I run in the 4mm position. Just wondering if I should go ahead and order new parts or what should I expect. It also still has 2mm washers on the rack for ackerman, the guide recommends 0 if running the 2mm position for the trailing insert. Just looking for advice I guess before I start tearing it apart and rebuilding it. Thanks
mxturd is offline   Reply With Quote
Old 12-10-2015, 03:12 PM   #17197
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Some people glue in the inserts, and just purchase multiple spindles to get their 0, 2 and 4 options.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 12-10-2015, 03:45 PM   #17198
I understand the gluing of the inserts, just not quite sure on what to expect from the car. Just noticed the C block is the 2.5+2 instead of the stock 3+1 as well. I'll probably just order the stock parts and get it back to box stock and go from there
Old 12-10-2015, 04:16 PM   #17199
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Don't sell it! When converting the B5 to the B5M, the only part you need is the V1 tranny case and everything will work. Part #91530. If you want to use the included V2 case you'd need to get a new top shaft and bearings which is more expensive.
https://www.teamassociated.com/parts...1530-gear_box/
If you contact AE and explain that your conversion kit came with the wrong transmission case (mine did as well), they might send you one free of charge.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 12-10-2015, 04:35 PM   #17200
Anyone know what size spur the CE version comes with? Thanks
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-10-2015, 04:37 PM   #17201
Jmuck69's Avatar
81, standard size for AE buggies.
B6D | B64D
Old 12-10-2015, 04:57 PM   #17202
The B5M came with a 81 and 72, the lite came with 78 and 69.
Wondered which set the CE comes with...
TLR 22 3.0
Apex RC Proshop
Old 12-10-2015, 05:05 PM   #17203
Download the manual which should tell you which spurs are included.
AreCee is offline   Reply With Quote
Old 12-10-2015, 05:06 PM   #17204
Kalio's Avatar
The CE also includes the 72 spur gear. At least mine did.
(Jason Shank)
Current: RC10B5m CE, RC10B44.3
Retired: RC10B4.2 RS
Tracks: Pitstop Hobbies, Bumps & Jumps
Kalio is offline   Reply With Quote
Old 12-10-2015, 05:30 PM   #17205
The CE doesn't have a model specific manual like the lite does. Only a supplementation. So I guess you go by the standard B5M manual.
TLR 22 3.0
Apex RC Proshop
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
