    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-09-2015, 05:22 AM   #17176
shannow's Avatar
Originally Posted by beidle99 View Post
there are no wheels in any kit.
In the original B5m there were. I had a complete set.
shannow is offline   Reply With Quote
Old 12-09-2015, 06:03 AM   #17177
Trader Rating: 15 (100%+)
Only the b5m team kit came with wheels.
No wheels for the L or CE
motoman811 is offline   Reply With Quote
Old 12-09-2015, 06:21 AM   #17178
5tone's Avatar
No wheels , only one front wing (not fitting the B5 front shock tower)...
I don't know the english words...
but in france we use to say "faire la pince !"
5tone is offline   Reply With Quote
Old 12-09-2015, 07:08 AM   #17179
Lexicus's Avatar
Trader Rating: 19 (100%+)
Default Stock Racing upgrades
I've loved how competitive my Lite is for stock racing out of the box so I haven't felt the need to spend too much (to date nothing other than AE xrings) on upgrades. Now with plenty of time with the car I'm thinking of doing some simple upgrades. Specifically, wanted opinions about Schelle Racing Ceramic Gearbox Bearings and MIP Bi-metal pucks. For those that have upgraded upgraded to these have you felt that it's worth the money? Racing indoor over the winter but outside for summer. Any worries with Ceramic stuff and outside dust? Anything more important that I should consider? Thx!
Lexicus is offline   Reply With Quote
Old 12-09-2015, 07:59 AM   #17180
Nick_n's Avatar
Pucks and cermanic bearings are both great upgrades.
Nick_n is offline   Reply With Quote
Old 12-09-2015, 08:03 AM   #17181
Super Moderator
Trader Rating: 17 (100%+)
my car has the Avid Aura ceramics in the trans and the cut gears and just those two items alone woke this thing up. I just added the Schelle slipper lock out and I ordered Pucks. Figured I'm all in now, might as well blow the whole wad
I'm also running my 17.5 car in mod so I'm looking for every advantage at this point. Mod guys are in the mid 19's for fast laps and I just cracked 20.4 so I'm close.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-09-2015, 08:26 AM   #17182
Originally Posted by Kalio View Post
I didn't get any wheels either.
That is what I said as I went through my box. So I happily placed a 10.00 dollar order
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 12-09-2015, 05:34 PM   #17183
shadowracer24's Avatar
Originally Posted by caltrigger View Post
I have the same question. Also looking at a modern gen 2wd buggys and see a lot of them are built for high grip. Here in South Africa in my region we still need to build a track but we will only have a dry, med to low grip more than likely. We want to create an indoor track as well out of carpet for promotional purposes but I doubt one can can be adapted to all situations?
I run my lite on both high bite and loose to med bite tracks and all I change from each is the tires and a different diff and slipper setting. Works great on both. If running mod you may want the heavier chassis on loose conditions.
shadowracer24 is offline   Reply With Quote
Old 12-09-2015, 07:45 PM   #17184
mick33b4's Avatar
I run a B5m on loose dirt. I've posted it several times, but it's worth mentioning again. The Ray Munday B5M guide is spot on for loose and outdoor conditions. Was perfect for getting going on my local indoor clay track as well. It's a really great overview of where to tweak for different conditions. Best changes you can make are green springs, 3.5 rear toe, B5R rear arms with hubs forward. Ray likes to add rear weight, but that seems to generate too much rotation momentum for our loose surface. I alternate between Hole Shot fronts when the surface is damp (higher grip), and Rips when it's dry and dusty. If you read through Ray's posts, he states mid beats rear under almost all conditions. At any rate, no need to wait for another generation. This car is current state of the art!
mick33b4 is offline   Reply With Quote
Old 12-09-2015, 11:52 PM   #17185
Suspended
I'm about to get a b5 or b5m. I don't care what is faster, but can someone tell me which is more fun to drive and which can turn tighter? Mid motor is better on high traction and rear motor for low, but I only want the one more fun. I prefer oversteer more than understeers.
latentspeed is offline   Reply With Quote
Old 12-09-2015, 11:58 PM   #17186
Suspended
Also will be running mod motor.
Old 12-10-2015, 06:08 AM   #17187
touringdriver's Avatar
Originally Posted by touringdriver View Post
Okay i need some help. purchased a nice used stock b5 buggy and a new b5m conversion kit for it and the 5 upper shaft bearings are 2 big in dia. to fit the upper shaft holes. i ordered all new upper crap for the m and its the same size as the5 case parts. however it all has different part numbers ( bearings, shaft and spacer. was there a batch of buggies that were released with wrong parts?
Well the V2 case did not fix issue. Can anyone shed a light on this issue? A friend said there was a running parts change but I can't find any part numbers. Almost ready to sell this thing and find another brand.
Proudly Sponsored by: Mr. Crash Racing, RickyRacer lidz & Ebay..
Rock Chalk Jayhawks
2014 Subway Cup & Dee and Mees On-road Race Schedule:
http://www.rctech.net/forum/kansas-m...l#post11891510
touringdriver is offline   Reply With Quote
Old 12-10-2015, 06:32 AM   #17188
Your Rock Chalk signature makes me think you might live in Kansas... If you live around KC, take your car to Fastlane Raceway in Blue Springs, MO. I'm sure there are a few of us that can look at what you have and get you going.
bshack is offline   Reply With Quote
Old 12-10-2015, 08:20 AM   #17189
Jerm13's Avatar
Trader Rating: 36 (100%+)
5x10x4 bearings correct....have you tried another set of bearings?
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 12-10-2015, 09:29 AM   #17190
If I use the 3.5mm toe in with the c mount can I still have the arrows in on the d mount?
DIRT DIGGER is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
