    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-08-2015, 11:21 AM   #17161
Kalio's Avatar
Just curious, does anyone know what difference there is between the regular (black) bearings and the new FT (blue) ones? Other than just being "better" somehow.
Kalio is offline   Reply With Quote
Old 12-08-2015, 12:12 PM   #17162
Trader Rating: 18 (100%+)
They have a metal shield on the other side for less drag. They are GREAT!
iTz Nicholas72 is offline   Reply With Quote
Old 12-08-2015, 03:32 PM   #17163
Originally Posted by BRSracing View Post
The play is normal, its been on all my B5Ms 3 or 4 gear. The stock slipper works fine with the play but i have found when using the Avid or Schelle slipper it rubs on the motor plate a little.
yeah... i put the 4 gear back together with the old top shaft after posting and saw it also had some play, to my surprise. I went with it for now, i will order up some shims.
i also ordered diff shims when I bought everything, but didnt need them.
thanks guys.
shdwboxn is offline   Reply With Quote
Old 12-08-2015, 05:44 PM   #17164
Thought of getting a B5M, but the standard kit is discontinued. The Lite edition looks good in all, but it seems to favor high bite track(we run on dusty/dirt) Should I just wait for B6M/B5.1M that I hear rumors about?
redbones is offline   Reply With Quote
Old 12-08-2015, 05:51 PM   #17165
tsair's Avatar
Are the fast guys buying bearings with two rubber shields and just taking them both out (at least for the tranny)? That seems like the lowest friction bearing for areas without dirt.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 12-08-2015, 06:37 PM   #17166
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I plan on running Ceramic bearings.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 12-08-2015, 07:53 PM   #17167
bru00z's Avatar
I have a lite that has been great in 17.5 stock racing and just stepped up to mod. It has been been awesome with only a few setup tweaks and no extra weight at all. Here is Australia most of our tracks are outdoor low to medium grip at best too so didn't expect it to be as easy to setup as it has been
If I was buying a kit right now it is hard to go past the Championship Edition but you wont go wrong with the lite either.
Alex
Team Associated / Ace Hobbies / Proline Australia / VRP
bru00z is offline   Reply With Quote
Old 12-08-2015, 08:59 PM   #17168
a1
Would a 4 gear transmission work better than 3 gear in a mid traction dusty track? B5m lite
a1 is offline   Reply With Quote
Old 12-08-2015, 09:23 PM   #17169
Trader Rating: 29 (100%+)
I would lean towards yes. It puts a little more weight over the rear and and motor rotation helps. I would definitely give it a shot and its easy enough to change that it definitely can't hurt to try.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-08-2015, 09:25 PM   #17170
Jerm13's Avatar
Trader Rating: 36 (100%+)
It could... Takes some of the snap out of the acceleration and gives you a little kinetic weight transfer on and off power.
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 12-08-2015, 09:28 PM   #17171
Jerm13's Avatar
Just finished my daughters CE build. Everything about it was awesome. Easy and straight forward. Got it all done and was going to get it set up for this weekend and...... I don't have any front wheels that fit this thing!!!
And yes... that is pink wire!
Old 12-08-2015, 11:42 PM   #17172
5tone's Avatar
no wheels in the CE kit ? or it's just mine...?
5tone is offline   Reply With Quote
Old 12-09-2015, 01:06 AM   #17173
I have the same question. Also looking at a modern gen 2wd buggys and see a lot of them are built for high grip. Here in South Africa in my region we still need to build a track but we will only have a dry, med to low grip more than likely. We want to create an indoor track as well out of carpet for promotional purposes but I doubt one can can be adapted to all situations?
Some things are just better small!!!
caltrigger is offline   Reply With Quote
Old 12-09-2015, 04:21 AM   #17174
Kalio's Avatar
I didn't get any wheels either.
(Jason Shank)
Current: RC10B5m CE, RC10B44.3
Retired: RC10B4.2 RS
Tracks: Pitstop Hobbies, Bumps & Jumps
Old 12-09-2015, 04:31 AM   #17175
beidle99's Avatar
there are no wheels in any kit.
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
