    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 12-06-2015, 02:39 PM   #17131
shannow's Avatar
Originally Posted by joncmack View Post
Do you have any boost/turbo programmed into the esc at a specific rpm?
It's the trackstar gen 2 with it's setting pretty much stock.
I don't have boost timing (set at 0deg).
but I do have turbo set at 10 deg with a delay of 0.10s at full th and 20000rpm.
Scuffing I could try. The thing is that even on standstill will setting up. You never get twice the same nose lift height. It gets really hot really fast (I blip it for 1s max) .
shannow is offline   Reply With Quote
Old 12-06-2015, 03:02 PM   #17132
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by Jason Baliban View Post
And what rear springs are being used?
Thanks!
jB
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 12-06-2015, 03:23 PM   #17133
Jason Baliban's Avatar
Originally Posted by Jake S View Post
Those should be easy to track down! LOL
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 12-06-2015, 04:30 PM   #17134
Trader Rating: 15 (100%+)
The Yatabe Arena springs are a Yokomo brand of carpet and Astro stiff springs. I know Lee Martin carries them on his website amongst a few others.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 12-06-2015, 09:55 PM   #17135
Jake S's Avatar
http://www.amainhobbies.com/rc-cars-...s-1025/p417641
back ordered... but there you can get a better picture of what they are.
Old 12-06-2015, 11:32 PM   #17136
mblgjr's Avatar
Trader Rating: 86 (100%+)
Originally Posted by shannow View Post
White. I believe it's PTFE, no?
Heres the deal dont use white alone. Need at least 1 red in the stack if not 2. Went through same thing on my sct & set it just a little tighter than you think. Theyre picky. Just a faint nudge of the nut will change it.
mblgjr is offline   Reply With Quote
Old 12-07-2015, 02:46 AM   #17137
Sinnin's Avatar
From the FAQ in the first post of this thread....
Q: I just bought the aluminum steering bellcranks. Where does this little washer go?
A: It goes between the bearings. It acts as a crush washer.
So this is obviously false since there is a 1/4" space between the bearings. So seriously, where do they go?
Sinnin is offline   Reply With Quote
Old 12-07-2015, 06:18 AM   #17138
I didn't see where you stated which motor you are using? Since you posted, "the car would lift the front 1inch", I am assuming a mod motor below 17.5. For anything below a 17.5 you need one white pad, goes against the spur closest to the output shaft of the transmission. The other two pads are higher friction red pads and those go in the last two positions on the outside of the spur gear.
Fasttrak is offline   Reply With Quote
Old 12-07-2015, 09:21 AM   #17139
shannow's Avatar
Sorry yes. The motor is a trackstar 7.5. I think you are both right on the red pads... I should've bought them.
Old 12-07-2015, 11:21 AM   #17140
vfrninja's Avatar
Originally Posted by Socket View Post
Right. I also used the "hard" parts as they made the front end feel more precise.
The hard arms and c hubs are strong, but some at my track and myself included have broke multiple steering spindles. So I run all the hard parts on the front except those, but I do glue in the hard inserts to them.
vfrninja is offline   Reply With Quote
Old 12-07-2015, 12:05 PM   #17141
Jmuck69's Avatar
Anyone know what servo horn this is?
Thanks!
jB
The servo horn is the TLR metal horn for the 22. You have to drill and re-tap the hole for 3mm.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-07-2015, 12:16 PM   #17142
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
It goes between the bearings in the rack, not the bellcrank that you just purchased. They act as a crush tube so you can tighten the rack to the bellcranks.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 12-07-2015, 01:59 PM   #17143
Sinnin's Avatar
Thanks! I kind of assumed thats where they went. I just don't think many people are rebuilding their racks when they upgrade the bell cranks.
Old 12-07-2015, 03:40 PM   #17144
Outstanding! Thank you
j
Old 12-07-2015, 04:12 PM   #17145
Originally Posted by mxturd View Post
What is a good budget servo for a b5m
I like the Bluebird 616 buggy servo for buggies and the Exi D227 for SCT.
Eddie_E is offline   Reply With Quote
