    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-06-2014, 12:35 PM   #1651
Mason's Avatar
Originally Posted by TheBlueKnight View Post
I need to go back and shim the rear arms where they connect to the chassis. There was an unusual amount of slop there. I also was a little worried about how much slop the shock caps have on the upper shock mounts. The tops of the shocks can shimmy back and forth quite a bit at the upper shock mounts. I thought maybe I was missing something that might have needed to go in the shock cap hole but didn't find anything in the instructions
get yourself some heat shrink from harbor freight. There's a ginormous variety pack from pencil thin to cva axle diameter size or bigger. find one close to the shock bushing size and shrink it on. Done. This generally occurs when there are interactions of metric vs sae measurements. so perhaps they're the old design generic bushings but new cap holes?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-06-2014, 12:44 PM   #1652
Mason's Avatar
Originally Posted by proraptor View Post
Anyone have excessing play between the rear hubs and the rear a arms? I so what are you doing to resolve this?
You could seize this as an opportunity for additional wheelbase adjustment. any motor shim will work. knowing ae, probably just about any shim in the kit would fit too. I don't know the hinge pin sizes these days but an oversize ID shim isn't going to hurt in this case.
I got to fiddle with a partially built car last saturday and the rear arm was snug on that particular car. Don't know if he had to shim or not. On the RM Captcha went to the aluminum toe block and that took out any/all slop. Might be another option to look at.
Mason McCombs
Old 03-06-2014, 01:06 PM   #1653
predu's Avatar
WARNING . If you get the clamping front axles check the inner bearing seats all the way on.Mine had a ridge and damaged the bearing and is now notchy,This happened during installation, car has not been driven. While at hobby shop exchanging it and buying new bearings another guy there overheard me and said his does the same thing. That is 2 sets that were bad and there is probably more.
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-06-2014, 01:31 PM   #1654
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Originally Posted by Cautrell05 View Post
What are you guys coming up with for a ready to race weight?
Mine came out to 1590g. Beefcake!
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 03-06-2014, 01:37 PM   #1655
Stupid question, but did you install part 91414 rear hub spacers as called out in the instructions?
B5M & Stock Spec Slash.
The Certainty Principal - "Only the person who doesn't fully understand the problem has complete certainty about the best solution and its consequences. Certainty is proportional to the square of Ignorance (C≈IČ)"
Corners is offline   Reply With Quote
Old 03-06-2014, 01:42 PM   #1656
For a neater wiring job, did anyone consider to route the motor wires under the battery where the sensor wire should go…? Obviously some modding required incl the chassis, and possibly limited to 14G wire… any purists out there?
Pellefa is offline   Reply With Quote
Old 03-06-2014, 01:46 PM   #1657
BRSracing's Avatar
Trader Rating: 53 (100%+)
The bearings are an issue, clamp or no clamp. I don't think it has anything to do with your install.
BRSracing is offline   Reply With Quote
Old 03-06-2014, 01:59 PM   #1658
predu's Avatar
it's not the clamp it was a mismachined axle for the clamping hexes, i havent driven the car yet.
Old 03-06-2014, 02:49 PM   #1659
Graham11's Avatar
Trader Rating: 21 (100%+)
hey guys, now that some guys have had their b5m, what have been the thoughts on b5m vs c4.2, i have a decked out c4.2 and its great but i also have the chance to buy a b5m... or b5 tonight... in winter i run on indoor carpet and in the summer we will be running on a clay track outside.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-06-2014, 03:49 PM   #1660
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
so ... who here has done some old school dirt runnin with there B5M?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 03-06-2014, 03:55 PM   #1661
With all of the rain, snow, and freezing temperatures pretty much everywhere, I would say no one.
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 03-06-2014, 03:56 PM   #1662
tc1
Trader Rating: 15 (100%+)
Fixin on it tomorrow night!
tc1 is offline   Reply With Quote
Old 03-06-2014, 04:00 PM   #1663
Tech Legend
Cain's Avatar
If you can take em, love to see vids!
Old 03-06-2014, 04:23 PM   #1664
proraptor's Avatar
Ill check when I get home
B5M, Tekin RS pro with Tekin redline gen 2 8.5, Savox 1258TG
savage flux 2350, 7950th
Airtronics Mt4
proraptor is offline   Reply With Quote
Old 03-06-2014, 04:33 PM   #1665
VegasHB's Avatar
Maybe you got some junk shafts. I measured my 2 b4.2's and 2 sc10.2's . are all 2.93mm and both my b5m kits so 8 shafts are 2.93mm.
I hate to beat a dead horse now but something is up with the shock shafts. Don't wanna call Kody Numdendahl and Predu liars but there's more than just tolerance differences going on here, there's a substantial difference between my FT B4.2's along with my SC10.2 shafts and my B5 shock shafts.
Why would AE call out the fact that the new shafts are 3mm in their write up as far as new features.
Everyone grab their calipers, because aside from what the digital read out is, when I lock em down on the 4.2's and SC10.2 shafts and move right over to my B5 they don't come close to sliding over the shaft.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
