    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-23-2015, 07:47 AM   #16216
Originally Posted by hlpressley View Post
I see various post regarding different upgrades for the B5M FL kit. Are there any necessary upgrades? Upgrades that actually improve the car in some way? I am not a guy who necessarily cares for "bling" however, I don't mind spending for things that actually improve the car. Thanks in advance.
The only thing that was super necessary from the team kit was a durability upgrade, and that was the rear aluminum ballstud mount, which comes with the FL. Another good durability upgrade is titanium turnbuckles. Those are probably the weakest parts of the car and the first upgrade that was done. Everything else in my opinion is for looks. Not much is needed for the B5M to be good.
BrandonBreh is offline   Reply With Quote
Old 10-23-2015, 08:03 AM   #16217
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
For 17.5: MIP Aluminum Pucks and the Avid Evo Slipper.
For Mod: The Triad Evo slipper
I would get the 3x8mm grub screws to reduce slop in the front and rear hubs. The alum rear hubs are definitely not a required item. I have been on my "hard" plastic ones for almost a year.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-23-2015, 08:04 AM   #16218
Trader Rating: 478 (100%+)
I think X rings and a caged thrust bearing are must haves. I also like the aluminum C & D mounts but those are more of a luxury.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 10-23-2015, 08:07 AM   #16219
I do like the xrings better than the red orings for sure. Yeah, the Alum C and D are optional and do reduce rear a-arm play. I am on the fence with the caged thrust. I love the simple design, but thrusts do not seem to last as long with them. And the thrust does wear out. I have seen the balls fall out of the cage. I will probably go back to ceramic thrust balls and hard MIP thrust washers.
Old 10-23-2015, 08:19 AM   #16220
BRSracing's Avatar
Trader Rating: 53 (100%+)
Pucks HUGE waste of money, and the stock slipper works just fine.
BRSracing is offline   Reply With Quote
Old 10-23-2015, 08:21 AM   #16221
Yea i'd have to agree, those are the last 2 things I would upgrade.
Old 10-23-2015, 08:27 AM   #16222
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
I agree. The Lite really "needs" nothing out of the box. It already comes with all the options that most people were putting on the original B5m. Aluminum ballstud mount, Ti turnbuckles, and clamping rear hexes. The included aluminum front axles are just a bonus IMO.
The stock 2 pad slipper in the Lite kit, it will work fine for say..87.6% of people . The rest will opt to upgrade to an Avid/Schelle 2/3 pad system or a slipper eliminator, for stock.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 10-23-2015, 08:28 AM   #16223
Super Moderator
racer1812's Avatar
I'm gonna guess you guys don't run stock?
Old 10-23-2015, 08:35 AM   #16224
At one point I did, but came back to mod. Never really liked stock racing because of the cheating that goes on in club races. All it takes is a guy to run some esc timing and win the race because he can clear the triple for 7 minutes straight while the rest of the field needs to double single after 3 minutes. Of course nobody wants to call him out on it though because it's just club racing and nobody wants a fight.
But I guess yes pucks are a decent upgrade for stock racing.
Old 10-23-2015, 08:43 AM   #16225
Originally Posted by Socket View Post
The factory lite kit needs nothing out of the box. I always recommend a machined idler gear, and ceramic bearings, but they aren't mandatory.
I've seen you mention machined idler gears before, but I can't seem to find any info on them. Who makes them and where do they sell them?
dway100 is offline   Reply With Quote
Old 10-23-2015, 08:54 AM   #16226
http://www.shop.cbscustomrc.com/Asso...a-Set-CBB5.htm
Last edited by racer1812; 10-23-2015 at 08:57 AM. Reason: fixed to a direct link..:)
Old 10-23-2015, 09:11 AM   #16227
I wouldn't order anything from that site. I ordered a set a month ago and I haven't received it. No comunication at all. I currently have a claim open through PayPal. Ordered a set from Speedy's Racing products and had them in three days.
Sean B. is offline   Reply With Quote
Old 10-23-2015, 09:26 AM   #16228
I was thinking he was talking about actual machined gears, not cut stock gears.
Old 10-23-2015, 09:27 AM   #16229
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
He is talking about actual machined gears. He would need to tell you where / from whom he got them. Socket is also the type of person to tell you he has them and not tell you where you can get them.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-23-2015, 09:29 AM   #16230
BRSracing's Avatar
I actually have run stock a lot. The pucks improved zero for my racing and did not last as long as the stock parts on the car. I like the Schelle and Avid Slippers just fine but I have had just as good of luck with the stock system. The lite comes with the two pad system which works much better than the associated three pad system. The lite kit is good to go out of the box in my opinion. I dislike the plastic rear hubs with the inserts but people have run them without issue.
