    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-05-2014, 04:54 PM   #1606
mugenhatchie's Avatar
Running a 69/31 with a schuur speed 17.5. Same as I was using with my 4.2.
mugenhatchie is offline   Reply With Quote
Old 03-05-2014, 05:26 PM   #1607
AccessRacer's Avatar
Trader Rating: 20 (100%+)
Default in stock
Does anybody have these in stock?
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
AE RC8B3E TEKNO SCT410.3 JRC JET EDM & LATEMODEL
AccessRacer is offline   Reply With Quote
Old 03-05-2014, 05:33 PM   #1608
SilentHunter's Avatar
Check rcmadness in ct. I ordered one around noon and they still had some. $15 shipping.
SilentHunter is offline   Reply With Quote
Old 03-05-2014, 05:41 PM   #1609
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
Old 03-05-2014, 06:07 PM   #1610
VegasHB's Avatar
Originally Posted by predu View Post
If you want it done quicker the b4.2 big bore shafts are the same size and probably in stock at LHS.
Actually the B5 v2 shafts are a larger diameter. Just took some calipers to mine, the b4.2's were 2.96 and the B5's were 3.15. I believe Kody noted that the shocks have better pack due to this and the new inserts they use (black ones) to keep the piston centered better.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-05-2014, 06:10 PM   #1611
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
kody posted on fb that any difference in shaft thickness are difference in tolerances and not design
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-05-2014, 06:40 PM   #1612
Wade....'s Avatar
They are keeping some shit tolerances then.
Like I care. Can't wait to build mine.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 03-05-2014, 07:22 PM   #1613
VegasHB's Avatar
? wonder why they make note of it then in the features of the new kits. Just better tolerances? The diameter difference between my b5 and b4.2 is scary then
Below is what I was referencing incorrectly from Chad Due
Originally Posted by AEDUE View Post
No change in the 12 mm bore. The reason you are probably feeling this change is because the seal package is constructed much better. Therefore the shaft deflection is much less making the piston function better. This is also the result of the super smooth new shafts. Overall I would say they are the best shocks AE has ever produced
Chad Due
Old 03-05-2014, 07:48 PM   #1614
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Factory Team matched shock shafts available soon.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-05-2014, 08:52 PM   #1615
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by Jake S View Post
Any shots from under-side too?
Yep. And all dine with car. Serpentvfits good till I get b5 one painted.
vr6cj is offline   Reply With Quote
Old 03-05-2014, 09:01 PM   #1616
Just discovered your driving secret Jones... I need to wrap bacon around my mt-4 as well...
roundguy is offline   Reply With Quote
Old 03-05-2014, 09:01 PM   #1617
Trader Rating: 8 (90%+)
With all the QC issues with the kits, I had better open up the box and inspect all the known problems at the shop before accepting the car.
juicy74 is offline   Reply With Quote
Old 03-05-2014, 09:08 PM   #1618
vr6cj's Avatar
Lol.....u get one these things yet randy?
Old 03-05-2014, 09:15 PM   #1619
Had one before you did.. I took a bunch of pics while building it but I can't post links until I hit 10 posts....One more!
Old 03-05-2014, 09:18 PM   #1620
Only problem I really had was a shock collar with a slightly messed up thread. Would be hard to catch.
Overall the fit and finish seemed pretty good, although the collars do seem cheaper than the old BB shocks.
