    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-17-2015, 07:01 PM   #16126
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by mick33b4 View Post
So the new Pro-line Predator body looks sweet! However, Tower currently has it listed for $29.99? C'mon!?! A 1/10th buggy body for thirty bucks? That's short course crazy talk. The stock body is $13.99?
Then buy 2 stock bodies. It's a buggy body, will last forever.
Want an awesome body, spend the $ then.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-17-2015, 07:07 PM   #16127
can someone tell me which servo works best and doesn't suck up the juice like savox for a B5M?
gearit is offline   Reply With Quote
Old 10-17-2015, 08:31 PM   #16128
gokarter64's Avatar
dont order it from tower hobbys XD wait till amain or your lhs has them in stock
gokarter64 is offline   Reply With Quote
Old 10-17-2015, 08:38 PM   #16129
Can anyone suggest a durable wing for the B5M? Mine took quite the beating today, definitely time for a replacement.
Tbone17 is offline   Reply With Quote
Old 10-17-2015, 10:15 PM   #16130
Trader Rating: 18 (100%+)
Stock is best balance of strength and weight. Or the Proline Trifecta of you want all out strength.
iTz Nicholas72 is offline   Reply With Quote
Old 10-17-2015, 10:48 PM   #16131
Get the s works plastic rear wing they are a bit heavy bit indestructible. Lile really you can take a hammer to it. I have had mine for 6 months I think and a buddy's daughter has had one for over a year amain has them for 8 bucks I think
jslider is offline   Reply With Quote
Old 10-18-2015, 08:23 AM   #16132
SCTDan's Avatar
Originally Posted by man1ac View Post
Just read this:
Originally Posted by Hobbyking User
Terrible terrible product. Bought four of these batteries, 32 days later ( 2 days out of warranty ) the negative terminal melted on one of the batteries. 2 months later all four have melted negative terminals. Insuffient casing support around the 5mm ports. Don't waste your money like I did
I think I'll stick to the 8.5 even though its quite powerful. I am going to train with my DX4C and the B4.2RS so I think the next step should be the 8.5T (and this kind of motor is often suggested for the B5M (the Sonic Mach 2).)
I have been using 2 of those batteries in my B5M Lite for a couple of months and have had no issues. The one thing I do is use a small amount of dielectric grease on the connections so they don't require so much force. I have been doing this for years on all my battery connections and have never had a fraction of the issues people report about plugs melting and wearing out. You do have to clean the connections and reapply the grease frequently to keep them clean but I feel it's worth the effort.
B44.1
DESC410R
B5m Lite
Brakes? who needs brakes?
SCTDan is offline   Reply With Quote
Old 10-18-2015, 08:39 AM   #16133
Thanks!
Just thinking about which Motor/ESC Combo I should take...Kind of frustrated because I cant tell myself thats its a good idea to spent 680$ bucks ...damn my mind! Damn him!
man1ac is offline   Reply With Quote
Old 10-18-2015, 09:34 AM   #16134
Super Moderator
I thought a dielectric was an electrical insulator? Perhaps a small amount of electrically conductive grease would be something to try.
Dave H is offline   Reply With Quote
Old 10-18-2015, 10:41 AM   #16135
im just curious what the difference is between the hard arms and towers over the stock?
DIRT DIGGER is offline   Reply With Quote
Old 10-18-2015, 10:47 AM   #16136
Thanks, might give it a try. Just wonder if the mount will be a weak point if the wing is that much stronger.
Old 10-18-2015, 12:10 PM   #16137
thecman26's Avatar
In my experience Savox isn't any more power hungry than any other servo out there. The past issues were with the cheapo spektrum sport receivers. If you run them you will have issues but that's not the servos fault.
I just put a Savox 1258 Black edition in my T5M and its frikin sweet!
Old 10-18-2015, 12:45 PM   #16138
SCTDan's Avatar
Where the contact between the metal pieces is solid the grease is pushed out and does not add any resistance. In the loose areas it remains and helps prevent arcing and corrosion. I've done resistance tests and have not seen any difference in the same connection with and without the grease. However with it the connection does go together and come apart easier.
B44.1
DESC410R
B5m Lite
Old 10-18-2015, 06:41 PM   #16139
3srcracing's Avatar
Trader Rating: 25 (100%+)
For those of you running the +4mm mount, what o rings come in the kit thats "required" to run them?
Can you just run the generic orings, or did they get thinner ones?
3srcracing is offline   Reply With Quote
Old 10-18-2015, 07:10 PM   #16140
What is involved and what parts do I need to change my 4 gear trans to a new 3 gear ? And will a Schelle clutch work on it afterwards
Stampy79 is offline   Reply With Quote
