    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 10-06-2015, 02:47 AM   #15886
Volition's Avatar
Originally Posted by Dave H View Post
Your'e thinking of using the torque wrench to measure the actual diff action, right? Not the diff bolt torque?
At the very least I don't think the linked wrench is the correct tool. That appears to be a version of what some call a torque-tension tool with a 1/2" socket drive, used for final torquing of fairly substantial full scale bolts. Not sensitive enough, and the angle part doesn't apply.
With a far more sensitive/lower range torque only wrench it might be possible at least to an extent. I think the best chance of success would be on the bare diff out of the car. The torque is so low that things like driveshaft binding and hub bearings would add to the challenge.
Interesting idea, if you do try it I would like to know how it works or doesn't.
Correct, I don't think it would work with the diff thrust bolt. Idea was to hold one wheel, put wrench on the other wheel and check torque then.
As a background I drove a 4wd short course last summer. Loved the buggy racing so bought a 2nd hand b5m I've spent the last month and a bit tearing it down and rebuilding and will try my hand at 17.5t Blinky racing. On my first attempt of building the diff I snapped the thrust bolt. So disappointing as I'd put in all the hard work and was excited to get driving & bam. So I ordered the bolt. I'm in Australia 2 weeks later it arrived. In that time I did some research and successfully built my diff. Learnt plenty on the rebuild. Installed a few new things which was fun. Bearings, aluminum hubs, etc have bought some spares. So in total I have 2 battery packs of experience in 2wd, in buggies, in stock.
I just thought there has got to be a way to measure diff tightness reliably. All the methods around are so subjective and impossible to convey "a feel". So I thought I'd ask the question? Personally I'll ask someone at the track to check it out and guid me so I can feel the correct tightness for myself. Love a way to have. An instrument that said yep you've got the right tightness. Honestly hoping someone else had tried it and could definitively say it does or does not work. Anyone want to try it out for me? As I said, if I get time and I haven't got more important things to worry about ill try it.
My thinking in regards to all the variables is that the wrench gauge would take that into account. E,g. If the diff balls are being pressed with the same force. Yet due to variables ( plastics, etc as Socket mentioned)one is looser then the other.
The gauge would measure exactly that. It would show one as looser then the other. All speculation of course.
Without someone actually testing it we will never really know. Rcbuddha stated he had tried it without much success. So I'll take that as correct unless I hear or see different for now.
More importantly I have a million questions. So hopefully you can be patient enough with my naivety.
Thanks all in advance.
Volition is offline   Reply With Quote
Old 10-06-2015, 02:53 AM   #15887
Volition's Avatar
I've done some searching without too much success. Has anyone done a chart of which pin ions will fit on which Spurs.
I found out that a 25pinion is the smallest a 76spur will fit, or is that 72 shit I'll have to count the teeth on the spur gear I've got on the car.
Anyway has anyone done the legwork on this already. I have a few Spurs that I bought And want to now the smallest and largest pinions for 66, 69, 72, 76 & 81
Old 10-06-2015, 03:31 AM   #15888
Originally Posted by Silberpfeil View Post
How much longer till we get a worlds kit?
No need to wait, we race whit the same cars in France for half year.
Go to Facebook at Redworkshop and order lowrider. ( or b52 if you race carpet)
joss9999 is offline   Reply With Quote
Old 10-06-2015, 03:35 AM   #15889
The concept on the lowrider and b52 (the b52 is the same layout thant tebo kyosh) came naturally to nord France beacose we race on astro and carpet.
Old 10-06-2015, 04:21 AM   #15890
WonTonsChicken's Avatar
Trader Rating: 42 (100%+)
That is an interesting concept with using a beam type torque wrench, but I think the only thing that would have benefit, is that if you have a rough range of tightness to a given type of track surface (i.e. 15-18"lbs for medium grip / 20-22"lbs for medium/high grip) But, I would leave those assumptions for a simple starting point at the very most.. Interesting idea though!
--Special Thanks to--
Tekno RC - Pro-Line - Boca Bearings - Team Tekin - FTM Grip - G's RC Raceway - CowRC!
Tekno ET48 | NB48 | EB48.2 | SCT410 | AE B5M | Pro-2 SC
WonTonsChicken is offline   Reply With Quote
Old 10-06-2015, 05:13 AM   #15891
danny d's Avatar
a local racer made a diff tester when we were running touring cars. It was a basic load tester.... a wrench with a weighted lever. Way too much work for a diff in a car.
danny d is offline   Reply With Quote
Old 10-06-2015, 05:44 AM   #15892
Jmuck69's Avatar
Originally Posted by afm223 View Post
When using the Associated aluminum rear hubs, which position is closest to the stock setup? Also will I need any washers between the ball stud and the hub?
Go to AE's website and look under the B5M manuals section. They have a PDF supplement that explains the hubs and what to do to match stock position.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-06-2015, 06:52 AM   #15893
Razathorn's Avatar
LOL I did this a few years back just to explain the same idea to a friend.
+ YouTube Video
https://www.youtube.com/watch?v=C_1I1Hiw8XM
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-06-2015, 07:58 AM   #15894
Thank you!
afm223 is offline   Reply With Quote
Old 10-06-2015, 11:51 AM   #15895
I doubt it will be the exact same car. Since it's a really "track specific" configuration.
It wil probably be more like the "B-drivers cars"
http://events.redrc.net/2015/10/new-...orkshop-jtprc/
- lowered shocktower
- different hubs
- maybe some steering parts
and maybe someday a LG transmission with a forward shock option.
But as explained by others earlier you can already order a LG 3- or 4-gear transmission form RedWorkShop.
janus_77 is offline   Reply With Quote
Old 10-06-2015, 11:58 AM   #15896
Suspended
Trader Rating: 61 (100%+)
That 3 gear kit is super trick.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 10-06-2015, 01:39 PM   #15897
gokarter64's Avatar
here are some screens of the worlds winning 2wd courtesy of redworkshop
ae made a smart move working with him to make these new parts. redworkshop is now offering the worlds lowrider kit for sale. pm him on facebook if your interested.
personally im thinking of making my old b5m a dedicated carpet/turf car (we really dont have any of those surfaces here though). i have no other use for it and i like messing with stuff
gokarter64 is offline   Reply With Quote
Old 10-06-2015, 01:54 PM   #15898
Jmuck69's Avatar
This is not the Worlds winning car of Rivkin, he doesn't race Orion Motors.
B6D | B64D
Old 10-06-2015, 02:01 PM   #15899
gokarter64's Avatar
its not specifically rivkins car but it is the same stuff ae used on on their cars for the worlds
Old 10-06-2015, 02:14 PM   #15900
Jmuck69's Avatar
This is the back of Rivkin's buggy. Shock tower re-positioned to be front of A-Arms. Not sure how transmission connects.
B6D | B64D
