    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 10-03-2015, 07:53 AM   #15841
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Looks like JConcepts has been busy ... lots of new things in this picture...
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-03-2015, 08:00 AM   #15842
I wonder if they are running these new CVA from JConcepts in Japan?
http://www.rccaraction.com/blog/2015...-factory-lite/
Fasttrak is offline   Reply With Quote
Old 10-03-2015, 10:42 AM   #15843
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I didnt see those in any of the pictures
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-03-2015, 02:52 PM   #15844
gooba's Avatar
I would bet that Jason has them on his personal car for testing purposes
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 10-03-2015, 04:37 PM   #15845
gooba's Avatar
Ive studied that last pic which is Jason ruona's personal car and its hard to tell but it does look like he has the new axles. I'm also seeing carbon fiber front and rear shock towers and a new camber mount brace combo. Also he looks to be running a 4 gear trans
Old 10-03-2015, 05:15 PM   #15846
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
Originally Posted by onekiwi View Post
What a cool track, looks like a lot of fun.
Pretty sure they are running the redworkshop low rider, On high grip im sure it will be great but on med grip im not too sure.
Digger I hope you will now put in more time with driving it stock or the setup you choose rather than chasing others setups.
Id spend a good chunk of time driving and keeping it wheels down first.
Tyres and track time. Absolutely NO offence intended.
+1
very cool track. some great elevation changes, good jumps, some wide areas to pass. would love to race on that track.
RC*PHREAK is offline   Reply With Quote
Old 10-03-2015, 07:21 PM   #15847
Anyone themselves or seen many running the Gear Diff in the Factory Lite?
Seen in a PDF from the AE webpage about the Roar Nats Cavalieri running them in the buggies and ball diffs in the trucks.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-03-2015, 08:34 PM   #15848
hello all im looking to get some feedback on cavi's roar nats setup? is it good or bad? thanks
DIRT DIGGER is offline   Reply With Quote
Old 10-03-2015, 09:01 PM   #15849
tsair's Avatar
Is there a list anywhere of a B5 to B5m lite conversion? I have an old B5 lying around I don't drive, and will probably start racing 17.5 pretty soon.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 10-03-2015, 09:12 PM   #15850
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Worked pretty good for him...I don't know what you're looking for. Unless you race on super high bite edgy clay then I would say look elsewhere.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-03-2015, 10:14 PM   #15851
tsair's Avatar
OK, I took a shot at making a list based on comparing the B5 manual and the B5M factory lite manual:
B5M Factory Lite Chassis ASC91511
RC10B5M Chassis Plate ASC91512
RC10B5M "3 Gear" Gear Box ASC91607
Aluminum Factory Team "3 Gear" Motor Plate (Black) ASC91602Team Factory Team "3 Gear" Top Shaft ASC91606
RC10B5M "3 Gear" Gear Cover ASC91604
RC10B5M Chassis Cradle ASC91514
3x8mm Flat Head Screw (20) ASC25201
3x10mm Flat Head Screw (20) ASC25202
Aluminum Front Axle Set (2) ASC91411
3mm Locknut (20) ASC25215
RC10B5M Composite Arm Mount Set ASC91532
RC10B5M Rear Shock Tower & Camber Mount ASC91518
RC10B5M Wing, Body Mount & Bumper Set ASC91531
RC10B5M Aluminum Rear Ballstud Mount (Blue) ASC91520
3x18mm FHC Screws (10) ASC89209
Factory Team 5x10x4mm Bearings (4) ASC91560
RC10B5M Chassis Brace ASC91521
3x0.5x6mm Button Head Screw (6) ASC31531
Heavy Duty One Way Shim (8) ASC1733
Factory Team "V2" Slipper Hub Set ASC7485
3x10mm Button Head Screw (20) ASC25211
RC10B5M Battery Strap ASC91534
This doesn't include the HD axles, aluminum rear hexes or body. Not sure if you need all the screws and stuff either.
Right now this is showing up as $223 on Amain before discounts.
Razor RC blog:
Old 10-04-2015, 01:31 AM   #15852
Trader Rating: 137 (100%+)
Originally Posted by racer1812 View Post
Isn't that the never ending question and variable? What is considered med vs. high grip. Low grip is easy to figure out.
High grip requires slicks, medium requires a tire such as chainlinks, other treated tires, low grip needs pins.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-04-2015, 11:20 AM   #15853
anyone know how to put the front axle height to up postion?
Old 10-04-2015, 11:38 AM   #15854
Thomas PA's Avatar
You can pick up a conversion kit for somewhere in the $80 range
Thomas PA is offline   Reply With Quote
Old 10-04-2015, 12:06 PM   #15855
tsair's Avatar
That's a B5 to B5M Heavy conversion though, right?
I just added up the parts. I think the conversion kit + chassis, 3 gear, motor plate is about $80, so you can get close for about $160. Still no titanium turnbuckles or HD axles that I forgot to include in the original list.
Seems like the cheapest option is to just sell the B5 for $100 or whatever and buy a new kit.
Razor RC blog:
