    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 09-21-2015, 06:41 PM   #15646
xray2050's Avatar
Trader Rating: 14 (100%+)
Anyone know what the part number for the front axles Cavaleri had on his B5M ROAR winning buggy? I have the clamping hexes but need the axles.
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 09-21-2015, 07:02 PM   #15647
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Cpt.America View Post
I run:
24mm ride height front
23.5mm ride height rear
-1 camber front
-1.5 camber rear
I'm going to try -1.5 and 23 rear and I think that should do it.
Does anyone run lighter oils than 32/30 in med to high grip? just curious.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 09-21-2015, 07:40 PM   #15648
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Took my B5M lite to the track today. It was my wife's idea because its our 8yr anniversary. Anyways most of the day I kept sliding the rear around and the track was a bit loose and kept trying to figure out what needed to be done. I changed the rear hub inserts the the B inserts and ran the outside hole and moved the upper shock position to the inside. This helped a bit and the car rotated a bit better.
I was running proline ribbed fronts and holeshot rears. So I finally tried different rear tires. I used Jconcept 3D tires and wow what a difference. The car gripped perfectly in the rear. Now I have a slight on power push but it's manageable. This is only my second time out with the car and I am really impressed with it. The car is super durable to. I had a few tumbles that I thought for sure it would break but nope flipped it over and kept on going!
My T4.1 I had there and snapped the arm coming off a jump and it landed on the pipe the first few laps. Did the same with me B5M and nothing.
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 09-21-2015, 07:41 PM   #15649
1/4milecrazy's Avatar
I run 27.5/25 or 30/27.5 depending on the conditions. But then again I will also run 32/30 if the conditions call for it.
Try different shock oils and see what works best for you. I know a guy with a 4wd SCT that runs 10 and 15 weight oils at our track. But he drills his own pistons, so that is what works for him and the way he drives.
1/4milecrazy is offline   Reply With Quote
Old 09-22-2015, 06:30 AM   #15650
Trader Rating: 18 (100%+)
When we are discussing Oil weights, shouldn't we also mention AE or Losi so we can get the CPS about the same? So, Losi 27.5/25 is like AE 25/22.5
http://www.rcrcr.com/index.php?optio...eral&Itemid=46
eragot is offline   Reply With Quote
Old 09-22-2015, 06:31 AM   #15651
Trader Rating: 30 (100%+)
I'm not sure what Cav was running, but most people with clamping front hexes are using the JConcepts front axle part# 2346
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 09-22-2015, 04:37 PM   #15652
BRSracing's Avatar
Trader Rating: 53 (100%+)
Anyone tried a gear diff in a b5m, and your thoughts?
BRSracing is offline   Reply With Quote
Old 09-22-2015, 04:43 PM   #15653
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I have not for 2 reasons:
- Diffs with plastic caps tend to leak more (but ae just released an alum cap)
- Changing the fluids for tuning is more effort than I want to do. If i run faster mod motors, I might get one, just because of the high bite surface I am on. The local factory drivers run a gear diff with only 2 gears, as opposed to all 4 in the diff.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-22-2015, 06:43 PM   #15654
AuPnMgt8b5m's Avatar
Default New to Forum Returning to Hobby after 26 yrs
Recently purchased a RC10B5M should have it by Saturday . Looking for direction on best set up . I'm think about purchasing A cheap AE transmitter and receiver/ some kind of sensor speed control and motor / 5800 70c 7.4 2s lipo battery / spektrum steering servo .
Associated RC10B5M/R / RC10GoldPan / Monster MGT 8.0 | Xray XB4 14 / XB2ce 16
Schumacher KR / Cat K1/K2 Aeros | Mugen MBX6/7e |TLR 8ight T | Corally PHI / RDX
BlackBox 410R|TrakPower MS-1|LRP Flow|Reedy|Savox|Radiopost |XPert |Futaba 4PKSR
AuPnMgt8b5m is offline   Reply With Quote
Old 09-22-2015, 07:40 PM   #15655
Jmuck69's Avatar
Why two gears? Less resistance or more oil capacity?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-22-2015, 07:59 PM   #15656
I was told less turbulence in the oil, more oil, so less hydro lock. I have not tried it yet.
Old 09-22-2015, 08:11 PM   #15657
Thinking of getting a Reedy Blackbox or LRP Flow Works Team?
I want to hear your experiences.
I don't want to hear about Orion or HW or any other speedo please.
Thank You!
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 09-22-2015, 09:46 PM   #15658
For anyone who switched from the 4 gear to the 3 gear running mod, whats your thoughts?
shark2288 is offline   Reply With Quote
Old 09-22-2015, 10:08 PM   #15659
xray2050's Avatar
Thank you.
Pete Elphinstone
Old 09-23-2015, 03:13 AM   #15660
JEFFs SC10's Avatar
Does anyone have a picture of this mod for the B inserts? I'm not sure since I'm new to AE.
I need to fine tune now.
Thanks!
XRAY 2017 T4
Xray X12-17' GT12
