    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-17-2015, 07:41 PM   #15601
Trader Rating: 21 (100%+)
Originally Posted by Wildcat1971 View Post
Awesome, thanks! How is the battery position measured?
drewbagel423 is offline   Reply With Quote
Old 09-17-2015, 07:50 PM   #15602
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I use a yard stick he is moving the pack forward 4mm and taping it in.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-18-2015, 01:48 PM   #15603
I'm curious why you guys are recommending a setup with super hard springs? Most of the setups I've seen seem to be stock white rears @ 2.10lb with white or grey fronts at 3.3 to 3.45lbs.
That setup posted above has 4.05 front springs with 2.4 rear.
It makes me wonder about trying something in between like blues front and rear to deal with the ankle high whoop section we have. All buggies have to slow a lot for the whoops at our track or we pack and end up upside down and my chassis is really scratched up.
Eddie_E is offline   Reply With Quote
Old 09-18-2015, 01:53 PM   #15604
CCristo's Avatar
Trader Rating: 55 (100%+)
That setup is for SRS which is silly high bite
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 09-18-2015, 01:56 PM   #15605
We run on a high bite, lower dust, and slightly bumpy surface. That is why I suggested the setup used by Humpty and the locals. My setup is close to humptys, with a few variations. I was actually doing my own tuning and liked the car more and more as I stiffened it up. I happened to notice one day, that many others were doing it also and following Humpty's setup. When I run flat front arms, I go a little softer. Like grey/blue fronts and grey rears. When I switched to the gullwings, I noticed that I liked the car even stiffer. You may not have the traction levels we do, since we run clay slicks, but humpty ran that same setup at OCRC, which is higher bite, but not slicks. In general, you should tune you car yourself and not use other people setup sheets. I prefer to tune my own car. I like the feel of my car and so have others I lent my car too. In fact a few people I know switched over to AE after driving my car. So it cant be all that bad
Old 09-18-2015, 02:05 PM   #15606
Chris, I'm specifically talking about the newest indoor layout at RCE. Have you been up there in the past 3 weeks?
Old 09-18-2015, 02:06 PM   #15607
onekiwi's Avatar
Originally Posted by BrandonBreh View Post
The first servo company (spektrum, savox, futaba, reedy, or any other quality servo makers) to make a low profile servo that has the wire that comes out the bottom of the servo case rather than the side is getting my money.
If it's not under warranty then I'd remove the rubber grommet and dremel a slot to the rear or at 45 then bend the wire out the opening. then shoe goo the hole. Works great.
onekiwi is offline   Reply With Quote
Old 09-18-2015, 02:22 PM   #15608
I agree the the B5M Light is not bad at all. I really like it. I've been tuning for my own driving style using tips from this thread and what I know from years of racing foam and rubber sedan. I have all the steering I need now. I'm still 1 full second off the pace compared to the top 5 guys who have been running on clay for years. When I see something way different and it's working, I tend to need to know why.
Old 09-18-2015, 04:46 PM   #15609
I wasn't sure if 4mm was measured from all the way back, or somewhere in the middle.
Old 09-18-2015, 06:20 PM   #15610
from the back
Old 09-18-2015, 06:46 PM   #15611
Trader Rating: 18 (100%+)
Ordered a Lite from Tower. Miss my old B5M. Going to go ahead and order the parts to run 4 gear since some of my local tracks can be pretty loose. Curious how I'll like the 3 gear on higher grip though...
iTz Nicholas72 is offline   Reply With Quote
Old 09-19-2015, 01:48 AM   #15612
Cridd's Avatar
Trader Rating: 16 (100%+)
When the term "gear up" is used to get a higher motor temp, does that mean a higher pinion gear for a lower fdr and higher top speed or lower pinion for more a higher fdr and more low end?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 09-19-2015, 03:32 AM   #15613
Super Moderator
Gear up means larger pinion and/or smaller spur. Lower FDR, less gear reduction. Like shifting up a transmission gear in an automobile.
Dave H is offline   Reply With Quote
Old 09-19-2015, 03:35 AM   #15614
Suspended
Trader Rating: 440 (99%+)
What turn motor is a good all around one for this buggy? I just picked up a b5m and will be running indoor this winter.
MattP is offline   Reply With Quote
Old 09-19-2015, 06:10 AM   #15615
depends on the track size and level of traction. I run a Reedy 8.0 turn on big tracks. I also have 9.5 turn that is perfect for a little bullring track i run at.
mgers75 is offline   Reply With Quote
