    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-28-2015, 06:27 PM   #15346
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Originally Posted by RCBuddha View Post
http://www.redrc.net/2015/08/rdrp-b5...ing-mount-set/
New from Revolution Design Racing Products and made for the Team Associated B5M buggy is an aluminium low-profile wing mount set. The updated design places the wing 7mm lower than the stock wing mount does, which leads to a lower centre of gravity and improved jumping both over small, medium and large jumps. On top of that the high-quality 7075-T6 aluminium part grants a better support for the wing which leads to better aerodynamics and also improved durability in the event of a crash. The wing mount set is available in blue or black anodising.
Wish they had screws and buttons instead of body clips.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 08-28-2015, 06:32 PM   #15347
Yeah I can't stand the body clips on the wings anymore. I got the JConcepts ones with the threaded screw holes and they come with a set of aluminum buttons too.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-28-2015, 06:57 PM   #15348
gogi108's Avatar
Does anyone us the 66t spur for 17.5 racing ? Any reasons for or against ?
Tlr 22 2.0,losixx4we,xxx4g, 22-4
Chargers RC
Trackside rc
gogi108 is offline   Reply With Quote
Old 08-28-2015, 07:00 PM   #15349
Interesting but curious if the fdr works out to something you can fit that big of a pinion on and have enough motor adjustment for proper engagement?
Fasttrak is offline   Reply With Quote
Old 08-28-2015, 07:20 PM   #15350
gogi108's Avatar
Would allow a smaller pinion , moving motor back , may provide more rear grip .
Chargers RC
Trackside rc
Old 08-28-2015, 07:22 PM   #15351
Lots of great responses, thanks guys, I'm going to work on figuring this out and will definitely report back what changes I make and the improvement... Or I'll come back scratching my head even more... haha...
Going to work on getting Dirt Webs Gold on the front to match my rear and experiment with moving the battery around. Also, more laps will help i'm sure.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 08-29-2015, 12:16 AM   #15352
carcrazy699's Avatar
I am in the same place you are. I am used to 4wd cars and getting this car is totally different. I am playing with adjustments also to get more front traction. I am running the same tires that some of the fast guys run but I think its not right for my driving style. It's all about doing small adjustments because they make a huge difference on this car. I usually take a note pad with me and write down what adjustment I did and then make notes on how it affected the car good or bad.
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 08-29-2015, 06:44 AM   #15353
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
When using the Low Friction X-Rings,should the green slime be used with them also?
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 08-29-2015, 07:37 AM   #15354
Suspended
Trader Rating: 61 (100%+)
I do not.
I do however soak them for an hour in shock oil before install.
NOT any longer than 1 hour.
Socket is offline   Reply With Quote
Old 08-29-2015, 07:39 AM   #15355
Suspended
Front traction in a 2wd car is not only the suspension and roll center setup, but also driving style and power input. This is where a 4wd driver can have trouble with 2wd.
Old 08-29-2015, 07:40 AM   #15356
Suspended
some use it and swear by it. The issue I had was the availability of plastic pinions to make up the size difference. I also didn't require the extra weight over the rear axle. 69 felt like a solid medium on the high grip tracks I raced on.
Old 08-29-2015, 08:21 AM   #15357
Cridd's Avatar
Trader Rating: 16 (100%+)
I do use green slime on them.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-29-2015, 08:28 AM   #15358
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Socket View Post
I do not.
How does the shock oil soaking help? The point is to try to avoid silicone shock oil coming into contact with any silicone based oring.
HB D815v2 (Nova Mito4) / HB D8TTE (Nova Mito7)
HB E817 (Hobbywing XR8 and 1900kv motor)
Associated B6D (Orion and Schuur Speed)
SEF is offline   Reply With Quote
Old 08-29-2015, 08:34 AM   #15359
Suspended
Kody had explained this better than I ever could. The point was to lube the X ring, and to slightly swell it. This provided a better seal without much change in stichion.
Some will say this is wrong, some do it, some don't.
Old 08-29-2015, 08:49 AM   #15360
SEF
SEF's Avatar
Ok, if the x ring doesn't provide a good seal than soaking them in oil to cause them to expand makes sense. I would probably try them first without the soak since this would be the lowest amount of stiction, and if they leak try soaking them.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
