    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 08-20-2015, 08:52 PM   #15196
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mgers75 View Post
$3.19 for an 8 pack @ amain.com. Not sure how much an 8 pack of traxxas runs. Only found a 4 pack with a bunch of spacers for $2.39.
The Yokomo's look just like AE's, going to pick up a pack with my next order and compare them
That is cheaper!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-20-2015, 10:28 PM   #15197
1/4milecrazy's Avatar
Originally Posted by Sean B. View Post
Thanks for the replies everyone
Actually, I believe that is what's causing it, as I am using the 2mm option on the spindles. Not much you can do about it when running 2mm. It moves the wheel forward on the spindles. I just started running the b5ML and using a buddies setup since he's been running it for a while. His wheels rub too.
If you are using the 2mm trailing (inline) option for the front you have to move the spacer from in front of the C-hub to behind (or vice-versa) and that will stop the rubbing. Figured that out because my T5M wheels were rubbing.
Basically you move the C-hub spacer where ever you need to to stop the wheels from rubbing.
1/4milecrazy is offline   Reply With Quote
Old 08-21-2015, 05:49 AM   #15198
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Originally Posted by Cpt.America View Post
I love mine. I run my carbon B5m on a relatively high bite indoor clay that, that isn't all that bumpy, and the car is fantastic.
I run my car with a full sized pack at 1550 (obviously not pictured)
Aside from the full-size battery, are your setups the same or similar to the regular setups for the B5M that pros usually run or do you need to make major/minor adjustments to make this chassis work well?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 08-21-2015, 08:19 AM   #15199
Razathorn's Avatar
Originally Posted by RCBuddha View Post
Those front wings remind me of this:
More like this IMHO:
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 08-21-2015, 08:21 AM   #15200
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
That will not keep it from rubbing. That merely changes the wheelbase to support the change in front axle location. When you go to the 2mm trail you are moving the axle in the spindle. When you space the caster block back you are moving BOTH the caster block and the spindle as one. I have not had any issues with rubbing of the ball cup on either my B5m or T5m.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-21-2015, 09:15 AM   #15201
Super Moderator
Since I took steps to keep my weight up with the much lighter chassis, and the overall distribution is the same, so far, I haven't changed a thing. The only thing I am going to be doing, is moving to a slightly stiffer suspension setup. This will increase my roll resistance, but with the improved cornering grip of the carbon chassis, I am hoping the overall traction is a wash. The stiffer setup should give me the edge on landings.
Just a thoery in my head... I will find out over the next couple weeks. I only get to the track once a week these days, so my test times are limited! Damn kids!
- RCSpecialties -
Old 08-21-2015, 09:25 AM   #15202
carcrazy699's Avatar
Trader Rating: 48 (100%+)
http://www.redrc.net/2015/08/schelle...shock-pistons/
With the release of the latest V2 “screw-on” style Team Associated 3mm shock shaft, Schelle Racing Innovations came up with some new 12mm shock pistons to fine-tune the shock setup. Available in the popular sizes 2×1.6, 2×1.7 and 3×1.4, each size is available in either a traditional flat piston or in a bevel design. The CNC precision machined Delrin pistons offer a precision cut outer diameter with smooth machined outer edge while the tight fit to the shock body reduces wasted blow by around piston edges. Each package contains two pistons, tuning guide, and bevel piston supplement.
Those look really nice. I am guessing they go on the TiN shafts? If so I am ordering the Fox shocks and those shafts next month and will get these Schelle pistons if so
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 08-21-2015, 09:32 AM   #15203
Super Moderator
They go on the V2 shafts. Available in both Titanium nitride coated (lasts longer) and chrome (smoother).
Old 08-21-2015, 09:42 AM   #15204
Oh ok so I can run them on my stock shock shafts then? Thats cool if I can!
Losi Ten-T
Old 08-21-2015, 09:57 AM   #15205
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
You KNOW you should really be consulting your local team driver on these things. What was his name again?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-21-2015, 10:00 AM   #15206
Super Moderator
If you have the V2 screw on shafts then yes. If you have e-clip shafts then you will need the old style pistons. Schelle has machined pistons for both versions of shafts....just make sure to chrome check what you're ordering.
Old 08-21-2015, 10:02 AM   #15207
Super Moderator
<--- this guy?
Old 08-21-2015, 10:06 AM   #15208
I have the stock e-clip that came with my b5m lite but will be upgrading soon.
Losi Ten-T
Old 08-21-2015, 10:10 AM   #15209
Super Moderator
racer1812's Avatar
<--- this guy?
I didn't know you were from Washington Matt?
Old 08-21-2015, 10:19 AM   #15210
Super Moderator
Oh...thankfully I'm not. I'm closer to where the real "team" guys are.
