    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-17-2015, 06:21 PM   #15136
Suspended
Trader Rating: 61 (100%+)
Originally Posted by RCBuddha View Post
None that I am aware of. Maybe message mantisworx?
The avid shock bushings don't wear out, at all.
Do NOT use the alloy caps.
Socket is offline   Reply With Quote
Old 08-17-2015, 06:23 PM   #15137
Suspended
Originally Posted by KAWIDAD View Post
Thanks for the reply. I am actually looking for the machined bushings and spacers that are installed in the bottom of the shock bodies(hat bushings and shock spacer).
Thanks rcbuddha for your reply as well
AH - I thought you meant for the mounts. I have some of these machined bushings, still. I won't ever sell them as they don't make them anymore...
Old 08-17-2015, 06:43 PM   #15138
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Yeah, I am not sure why no one filled that hole in the market.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-17-2015, 06:56 PM   #15139
onefast8's Avatar
Trader Rating: 41 (100%+)
Do the Avid bushings fit the AE standoffs?
Jake R.
onefast8 is offline   Reply With Quote
Old 08-17-2015, 07:01 PM   #15140
no. the avid bushings are mean to float on the screw. Since the FT mounts had the ball on top of the shock mount, I am sure the avids would be too small of an ID.
Old 08-17-2015, 07:43 PM   #15141
1/4milecrazy's Avatar
I would like to clear up the rear motor arm thing.
Rear motor arms on a MM should be mounted opposite? L>R R>L?
It gives more traction? Where? Mid corner? Going in? Coming out? Side bite? Forward grip?
I have great forward grip, I would like a little more side bite coming out of corners. 17.5 car running treaded tires. Usually Very well conditioned green Dirt webs, which are always great, but if I can get a little bit more drive out of the corners, I could do even better.
1/4milecrazy is offline   Reply With Quote
Old 08-17-2015, 09:15 PM   #15142
ray_munday's Avatar
Yes, they are swapped L/R. They give a slightly shorter wheelbase which puts a little more weight on the back tyres. This will give more rear bite, especially on corner exit. You also get slightly more rear grip under brakes.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 08-17-2015, 09:22 PM   #15143
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You run them reversed because the sweep is the opposite direction between the RM and MM cars. As stated above, they move your overall static weight towards the rear of the car. More weight over the rear tires gives you more rear traction everywhere.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-17-2015, 10:35 PM   #15144
roadblock's Avatar
Originally Posted by Dog Runner View Post
Can I assume that the Lite kit comes with the appropriate arms/towers, etc so you don't have to buy and swap parts from the B5 kit like we were initially doing with the B5M?
You assume correct. The lite kit is complete including the flat front arms and appropriate tower. I was amazed how much better it handled fo me than the regular MM.
Kevin Porchia
No team, no sponsors
Island Raceway, Lindenhurst NY
roadblock is offline   Reply With Quote
Old 08-18-2015, 11:47 AM   #15145
Eli
Eli's Avatar
If you dont find what you are looking for with changing the rear arms you can try lowering your rear roll center and possibly the front even. Im not sure how many inner ball studs you have on your inner camber links but adding a mm might help keep the car planted on exit. Start with the rear and see what happens and maybe add one to the front as well.
I learned tuning with camber links a lot when the 22 first came out, would change .5mm through out the day if the track was losing grip. hope that helps
Eli Westrup - SDRC Raceway
Eli is offline   Reply With Quote
Old 08-18-2015, 08:39 PM   #15146
Ray
Sounds good. I already have them, just have to bolt them on. I will probably try that tomorrow.
Old 08-19-2015, 02:48 AM   #15147
What's with the front rims rubbing on the outside ball cups? I was kind of surprised by that. Thought they may have figured that out here in the 21'st century!
Sean B. is offline   Reply With Quote
Old 08-19-2015, 04:04 AM   #15148
JDe
JDe's Avatar
Hello,
A quick question about piston and shock shaft combos. I have V1 and V2 shafts, I understand there is a difference with the screw and e-clip retention's but can you cross v1 pistons with v2 shafts? I have noticed the AE v1 pistons fit fine and are ever so slightly loose after screwed down, as in it can be rotated once the screw is down. I've also noticed a set of Schelle v1 style pistons fit very snug on the shaft, is that how it 'should' be?
Please excuse my ignorance,
Cheers
My Signature > Your Signature
JDe is offline   Reply With Quote
Old 08-19-2015, 07:03 AM   #15149
Originally Posted by JDe View Post
Hello,
Cheers
Unless you ream out the V2 piston, the hole is too small to fit on a V1 shaft. Accidentally ordered some mixed parts from Amain, didn't realize how messed up their "parts for this car" listing were and ordered a mixed set of parts. Decided this last weekend to rebuild the shocks and change up the piston valving front and rear and the V2 pistons would not fit and I didn't have anything to cleanly ream them out so had to purchase the V1 piston to finish the assembly. Not too sure how they absolutely should sit on the shaft, I would think that having them tight enough to not spin should not change how they perform in their damping characteristics. I will probably just ream out the V2 pistons to the size of the V1 set and keep them as backup set of 2 X 1.6 and 3 X 1.4.
Fasttrak is offline   Reply With Quote
Old 08-19-2015, 12:12 PM   #15150
celt's Avatar
I'd check what front wheel you are running...none of mine come close to the ball cups.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
