    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-12-2015, 06:44 AM   #15016
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Razathorn View Post
I run a b5m light w/ 4 gear on a really low traction outdoor track and it's great.
You'll need an idler gear, idler pin, idler bearings, heavy top shaft, heavy top shaft bearings, heavy top shaft thrust tube, 4 gear motor plate, and 4 gear gear cover.
EDIT: The heavy top shaft items won't be needed if using a V2 4 gear gear box. I had a V1 laying around and those are the parts I had to use.
Wayne
the new v2 4 gear case uses the same topshaft and bearings as
the b5m lite 3 gear
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-12-2015, 06:49 AM   #15017
Trader Rating: 48 (100%+)
the b5m lite 3 gear
Might be a stupid question but is there a difference between the new and old topshaft?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 08-12-2015, 06:50 AM   #15018
Dino_D's Avatar
Originally Posted by 5tone View Post
Hi all,
I plan to build a car for low grip tracks
Do you think that B5M lite with a 4 gear box is a good idea ?
What part do I need exactly, a 4 gear box and an idler gear?
Thank's for your help
4 gear box v2 (so you don't need to change the layshaft)
You might want to consider getting the brass C and D mounts for the rear to add more weight, and maybe even run a square or saddle pack.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 08-12-2015, 07:08 AM   #15019
Yes. the shaft diameter where the bearings go. 5mm vs 6mm. That is why they use different bearings
Old 08-12-2015, 08:27 AM   #15020
Razathorn's Avatar
I gotta tell ya, I really did not like saddle at all in my b5m. I felt like the car had more traction with a shorty.
The mid point for front to rear weight distribution is about in the middle of the battery area, so if you run a shorty, the car is lighter, but the weight is more toward the rear. With the saddle, the car is heavier, and there will be more weight at the rear of the car than with a shorty, but there is more weight forward on the front tires too, and that will make it feel more loose in my experience.
I run on a very slippery at times outdoor track and I run a light chassis with 4 gear and shorty all the way back and plastic C and D plates. I couldn't be happier with my car. I think people should really explore other setup options on their cars before they start slapping weight back there. I've done the weight thing and the setup thing (heck I slapped an oz of lead in the back) and honestly, setup changes had far more impact.
I've found that running the hubs in the "half hole longer B hub spot" really allows the car to rotate more entering a corner (instead of feeling like the car pushes) but then it has a lot more traction as you start to exit a corner. In other words it feels hooked up and confident in the right places. The standard A hole on the hubs makes the car feel like an old broken rear motor car to me--pushy on entry and then loose/coming around if you get on it a bit much. I also run my shocks all the way in at the back tower, and +2 (up) no washers on the brace for pretty low roll center. It's VERY confidence inspiring outdoors in loamy to dusty to grooved conditions.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 08-12-2015, 10:07 AM   #15021
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
Wayne
do you think you could pm me or post your entire set-up here? Sounds like you have same conditions i do.
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
Old 08-12-2015, 10:39 AM   #15022
5tone's Avatar
Really interested by your set up
5tone is offline   Reply With Quote
Old 08-12-2015, 11:08 AM   #15023
AccessRacer's Avatar
Thumbs up
+1
+2 Me also
AE B5M
AE RC10T5M
AE SC5M
AE B44.3
AE RC8B3E TEKNO SCT410.3 JRC JET EDM & LATEMODEL
AccessRacer is offline   Reply With Quote
Old 08-12-2015, 11:11 AM   #15024
+1
+2
Would love to see that setup. Also which inserts are u running 3+1?
My Credit Card
Old 08-12-2015, 11:43 AM   #15025
+3, me very interested too.
I recently put on the Brass C and D mounts in the rear and an Exotek Alum Wing mount on the rear to help with weight at the back to reduce the out of corner fishtailing for more forward bite.
I run the large brick square pack and have the Factory RC strap and will be looking at the Shorty packs.
But it is just competing with the Rear Motor cars out there on outdoor tracks.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 08-12-2015, 11:44 AM   #15026
Jmuck69's Avatar
-1 Not interested in the setup.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-12-2015, 12:01 PM   #15027
Trader Rating: 483 (100%+)
I'd like to see it too. I have a wet track setup that I could post up but it's really out there.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-12-2015, 12:09 PM   #15028
onefast8's Avatar
Trader Rating: 41 (100%+)
Anyone know how the mip eco top shaft lines up with CB cut gears?
http://www.amain.com/rc-cars/mip-17....p15080/p449867
It says it has less contact and just wondering if the actual teeth are narrower to one side or center? I'm just afraid if its off to one side there wont be enough tooth contact area...
Edit: running mm 3gear if it matters.
Jake R.
onefast8 is offline   Reply With Quote
Old 08-12-2015, 12:10 PM   #15029
carcrazy699's Avatar
I am interested in the setup. Sounds just like my track. The car does push and is a bit loose coming out of the corners.
Please post up for us or fill out a setup sheet and post it!
Losi Ten-T
Losi M8T/Hobbywing/Turnigy/Savox
A.E B5M Lite/Tekin/Trinity
carcrazy699 is offline   Reply With Quote
Old 08-12-2015, 05:13 PM   #15030
So I broke in my diff but never got it to stop feeling gritty. I tightened the diff to the point where i could not longer move the left wheel by hand (while holding the right tire and spur). I alternated holding one wheel while giving it a bit of throttle. It felt the same as it did before I started and I still could not turn the left tire by hand while holding the spur and opposite tire. I tested the slipper by holding both wheels and it sounded like the diff barked. I kept tightening the diff several times in 1/8 increments, breaking it in, testing the slipper in between each and so far it still sounds like its barking.
I don't know how far I should tighten it because its really close to being tightened all the way and yet it still sounds like its slipping... Been doing it for several hours now....
Fanatic01 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
