Driving differences between 2WD and 4WD?
I've been driving 2WD trucks and buggies for a while now, and picked up a 4WD SCT, partially because I wanted to race it, but mostly because it was on sale. When I drive it, it slides around quite a bit, and feels like it's just a heavy brick plowing into corners, and until now, I just assumed I had a bad setup, or that was how it was supposed to feel. Then, I let a skilled 4WD driver drive it, looking for setup suggestions, and he said it felt good. When he drove it, the thing stuck to the track and looked smooth and controlled. As soon as I picked up the transmitter, it started sliding around again. So, it's probably my driving.
I'm used to driving stock 2WD buggies and short course trucks, and this is a 4WD modified short course truck. What do you do differently when driving 4WDs? When do you brake, and when do you give it throttle? How do you approach corners? (Specifically, compared to driving 2WD)
with a 4wd, you normally try to not use the brakes as much and stay on the throttle, even if it is just a touch as much as possible, the front will pull you through...same thing if you start to spin, punch it and the power to the front wheels should straighten you out. I went though the same learning curve when I got an AE B44.2 buggy
The best way to transition from 2wd to 4wd is drive angry and give it lots of gas. If its pointed in the right direction, give 'er, the back won't step out like a 2wd, if you start drifting it a bit, steer the right way and give 'er, and don't be afraid of pitching it into the turns. You probably won't find yourself using much if any breaks, just the drivetrain drag will be enough, and always be on the gas a little bit except on entry, if its not turning on exit, give it a bit of gas. That's the easiest way of describing it. Drive angry.
I have center-one-way on my ZX-5, it rolls into corners off-throttle just like a 2wd
4wd calls for less finesse, you can be on throttle/brake even when the wheels aren't pointing forward. Strange that I just don't understand the fun.
Think road rage.
Think road rage.
Bracket, what 4wd sct did you get? just wondering
You still have to finess the car a bit. If you drive it like your 2wd you will find you can get away with more. You can get on throttle more and brake harder. Jumping is a bit different. All the fast guys in 4wd are very smooth.
Slow in , fast out . The 4x4 pushs a bit more , so your turn in mark is more important in my opinion. But , once you turn in , all the corrections come from the throttle , and you should be trying to get back on the throttle sooner. Thats a good way to take advantage of all that 4wd grip.
When I had my Kyosho Zx5 I noticed that it was more of a point and shoot driving style with little to no brake, and could power through turns without letting up on the gas much. They will go where you tell them too without having to really drive them a lot, unlike 2 wheel drive. Its hard to put into words, you just have to try it.
You can drive a well setup 4wd buggy like a train on rails, 4wd sct has to always be driven like a dumptruck on acid
Very good tips. Thx all.
The best way to transition from 2wd to 4wd is drive angry.
May I quote you on that?
awesome!
awesome!
biggest difference is that 4wd don't steer when the brakes are on, unless you chuck it sideways.
