Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1562
Go to #1 theory is it'll calm initial.
#1564
#1566
steering
Try setting your steering exp to -10 and slow down your servos responce, this worked for me, also make sure you radios steering is not set on high… speed…… . I also dial my epa down so the spindles dont hit the hub, when turned fully
#1567
well I finally finished the build of new srx2 mm. the only issue I have is when trying to mount the wing to the mounts, it seems that the wing sits to far forward and it hits the shocks. this makes it impossible to mount without modification. I had to cut recesses into the front of the wing to clear the shocks so it will sit far enough forward to use the original mounting holes. does this sound normal??
#1568
#1570
Hey guys im building my mm this week for stock.
Should i just run a saddle in it? I have both. I read some were for stock just use the kit setup and drop the oil to 25 and run saddles.
Also i read the orings leak, i have some AE x rings, will those work?
#1572
Sweet. You know if the ae x rings will work on the shocks?
#1574
Just wanted to post up how great this car is. I ran again yesterday one pack at an outdoor track that is not a "race facility", more of a private track. It is not "groomed" and maintained everyday. This car is just so awesome and easy to drive. Very forgiving, lots of forward bite and just a great car to drive. Thanks Serpent for such a fun car and thanks to Loosenuts for letting me run on their track.
#1575
I thought I saw a setup for the MM srx2 for 17.5 on facebook. I think it was called "fast setup" or something like that. I was trying to find it and I cant seem to. Does anyone have the pdf? or even know what I am talking about. I was gonna give it a try at the track tonight.
