RC8.2e ESC/Battery connector?
Well I got my RC8.2e on the way and I'm looking at the turnigy 4500mAh 4S 30C hardcase battery. However this battery comes with an HTX plug and my ESC has Deans....but I saw this connector also from hobbyking:
http://www.hobbyking.com/hobbyking/s...2pcs_bag_.html
So my question is: can I use this adapter between battery and ESC and have no juice loss? or is it better to just cut the HTX plug and solder a deans?
For 1/8 scale you wanna go the other way and go with bullet connectors or something bigger then deans. I went the same way I have deans on all my 1/10 stuff and I installed it on my RC8.2 but my RC8.2 kept cutting out and I could not figure out why. Till someone at the track asked me why am I using 1/10 connectors for a 1/8 buggy and that surprised me cause that was the only thing I didn't check. So I changed to the bullet connectors and I had no issues after that. So my advice is do away with the deans for better connectors for your 1/8 buggy. I use the bullet like you show from Hobbyking and had no issues whatsoever since I change to them. BTW is your ESC at least 120A if not you will burn it with a 4S battery.
Ok so has anyone used this connector? I want to race my truck but want to be sure there's no power loss or similar if I use it instead of replacing battery plugs
