Which Dremel or Rotary tool do you suggest?
I'd like to get a Dremel or rotary tool to take care of the typical light job associated with RC. Everything from cleaning up the edges of bodies and wings to that "take your Dremel" and do whatever mod that periodically you need to do with a kit.
I see there are some nice lipo ones now, but a corded one would be OK.
I'd prefer to keep it under $70.00, but I'll go cheaper if based on my needs there is no reason to pay such amount or more if there is significantly good reason to.
I suspect most of my use will be light and thought I'd get opinions here since my RC needs will account for most of its use.
dont go cordless imho...
all i use is a cheap dremel 100 (basic model, on or off only)
http://www.lowes.com/pd_525945-353-1...cetInfo=Dremel
believe its $38 at my local walmart too....
Best I have used after burning a couple of dremels
http://www.amazon.com/Proxxon-38472-...ywords=proxxon
Brushless motor and it sustains rpm under load so way more precise.
this one is awesome. if you go cordless, make sure it is lithium
http://www.milwaukeetool.com/power-t...rdless/2460-21
I know someone who had one of these
http://www.homedepot.com/p/Dremel-7-...6#.UnsuPk7nbIU
Worked pretty good but could get bogged at times
I use the basic Corded dremel and have no complaints. It does anything I need it to.
I use a variable speed dremel. Works awesome. I'm not a fan of knock offs
