Old 10-23-2013, 05:38 AM   #1
Thumbs up HELP with starting to convert LST2 truck to brushless motor
Hey there people... I currently have a LST2 that I am going to convert to brushless motor. I am going to buy a HPI Brushless Flux Tork 2200kv motor and looking for a compatible ESC?? I also have a LST Conversion kit on its way but any advice or help would be greatly appreciated...
Middo75 is offline   Reply With Quote
Old 10-23-2013, 06:16 AM   #2
lbenton's Avatar
Trader Rating: 48 (100%+)
If you are not going to run sensored motors I would suggest just rolling with the Castle Mamba Monster 2, or to get a first gen and waterproof it with liquid tape. They are durable and trusted without being over expensive. And I would assume that if you are putting it in a beast like the LST2 you would not be keeping it out the messy stuff.
The RX8 is a good option, but will cost more, and a lot of people also favor Hobbywing.
lbenton is offline   Reply With Quote
Old 10-23-2013, 06:34 AM   #3
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
If you are using the Losi conversion kit then the HPI tork motor will not work because of the heatsink on the motor...
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 10-24-2013, 03:39 AM   #4
Really?? Can I make it fit by cutting out any bit to fit the heat sink part?
Old 10-24-2013, 06:17 AM   #5
Trader Rating: 18 (100%+)
FYI a moderator moved your original thread to the Monster Truck section and there's more replies there. Here's the link: iNFORMATION needed about Converting a LST2 to Brushless Motor
The inside diameter of the Losi mount is 43mm. You could shave down the little nubs/heatsink of the motor but why? The HPI motor is made by Castle to HPI's cheaper specs, so the Castle is a better motor that fits without mods. You really should check out your original thread, I posted some important information about the limiations of the Losi mount you need to read before buying a motor.
LST XXL Castle MMM 1717 custom E-Conversion / TLR 8ight-T 2.0 Tekin powered / Redcat Ground Pounder / Traxxas Rally 1/10 / Tamiya Hornet shelf queen
Punch Control? I don't need no stinking Punch Control!!
Overdriven is offline   Reply With Quote
