Tamiya DB01RR
#241
I aslo want to know if the spring retainers #42271 are the same as those DB01RR Chassis Kit #84369 includes?
#243
I was wondering how much trf 501x aluminum caster blocks need trimming when used with double cardan joint shafts.
#244
Super Moderator
If they're the same ones I've used on my DB01 & now use on my TRF503, then they may not need any trimming(though I could be wrong). I've played around with a pair of DCJ's I bought for my TRF211 & it looked like they'd fit without any problems, but again please correct me if I'm wrong....
#245
I mean the front aluminum caster blocks. The manual of the double cardan joint shafts #42283 shows that if used with trf 501x aluminum caster blocks, there will be some areas which come into contact. I just wonder how big the areas are and it is easily to trim, because I am thinking of getting trf 501x aluminum caster blocks instead of the plastic ones.
#247
Super Moderator
#248
Battery compartment enquiry
hey all, can anyone please let me know the max lipo dimension that could fit the db01 chassis without any mods? thinking of getting db01 but my nano tech lipo measures 152mm long.
#249
Hello. I'm not near my car at this time. .....but I know that I have been able to fit many styles of "squared" lipo packs into my car with a little room to spare. I have the blue Hardcastle 5200 zippy pack from hobbyking and I also have fitted my Peak 4200 "shotgun" lipo without issues. Hopefully this might help but I could measure for you on Friday if you want.
#250
Super Moderator
Tamiya db01
Hi all i have a brushless db01 for sometime but having issues with the ball diffs. Been thinking of getting back into racing again. Should I bother with the upgrades or look for another 4wd buggy
#252
Thinking about picking up a DB01rrr to run as my 13.5 wheeler. Mainly run hard packed dirt and clay tracks with bite being low to med. Thoughts? Like the belt drive as well as it being sealed and really like the platform design. Plus I have not owned a Tamiya since the mid 80's and really would like to put one in the racing fleet.
#253
Nothing wrong with running Tamiya for the races....with the exception of my ARRMA Typhon, my entire race fleet is Tamiya. Have fun
#254
#255
Thank you for the info Obin and Jimmy much appreciated.
