DuckTape on outside of tires?
#16
Well doesn't just washing them take off the rubber, like using simple green or something?
#17
no
#19
Super Moderator
Trader Rating: 31 (100%+)
#20
It is also done when you are just putting an angle on the pins/bars of the tires to make them look and feel like they have a "few" runs on them. This is neccessary when you run on those wet clay tracks. The clay doesn't wear tires as much (if at all) like a dry dirt track. So to establish a "broken-in" tire while your trackside, you can spin them on a drill and use sand paper to det the desired tread depth and angle. Then use duct tape to remove the 'fuzz' left behind. This is almost not neccessary anymore with tire designs like the AKA Low Tread Depth (LTD) and Standard Tread Depth (STD) tires.
#22
I heard this works pretty well:
#23
Super Moderator
#24
Duck and duct tape are different.
Duck tape, aka 100 MPH tape, is different than duct tape. Duck is tearable by hand, with the cloth mesh embedded into it. Used by many in the military for various things, including sealing up ammunition boxes for water landings.
Duck tape should never be used on ducts as it is not approved by code (at least Virginia code, I'm sure others, as the adhesive dries hard over time and loses it's stick).
Duct tape is the shiny tape actually used to seal ductwork, foil based, and not tearable by hand.
#25
#26
Super Moderator
#27
#28
Super Moderator
Holy crap, how did I get sucked into a debate about DUCT tape, whether it's the common cloth type we all know, or the HVAC foil type..it's still DUCT tape..
For the record and on topic of this thread. Ducktape brand duct tape is the worst crap on the planet! I wouldn't even use it to clean tires like the OP is asking about.
#30
I used to have a roll of military grade duct tape and you could not tear it by hand. It had to be cut. It was strong stuff.
