Tool/trick to compare unmarked springs?
I've almost filled a large ziplock with assorted spare springs from various RC's I've owned. Most I can pair up by colour... but is there an easy way to compare them to each other? i.e. I have 10 pairs of springs and in the end I've sorted them by stiffness?
I can sort some at a course level by squeezing them... but others I've had to mount and look at ride height since they've felt so close. Is there a better way?
Only if the wire diameter is the same.
Easiest way to compare two springs is slide them both over a dowel or tool handle, end to end, and compress them both. The first spring to bottom out all the coils is the softer one. Just don't let them slip or they'll shoot across the room.
I've used a hobby vise, digital calipers, and a digital scale to measure springs in the past.
Spread the calipers and clamp one end between the rubber jaws of the hobby vise. Lay the digital scale on top if the hobby vise between the ends of the calipers.
Place a spring on top of the scale and measure its mass, say 7 grams. Then start closing the calipers until they just start to touch the spring. Zero the calipers. Then close the calipers by a known amount, say 10.00 mm. Then read the mass from the scale. As an example, it might read 560 grams.
The spring rate is the change in mass over the change in distance. In this case it's (560-7 grams)/10.00 mm = 55.3 grams per millimeter. To covert into pounds per inch, multiply by .056. In this example the spring rate would be about 3.1 pounds per inch.
http://www.acxesspring.com/spring-fo...alculator.html
I've used this calculator and it works well. Take a few measurements with calipers, plug in the numbers and you get the spring rate.
The scale reads grams, but it's really measuring gram-force.
That's exactly how I do it...it gives you a pretty good idea!
I place a digital scale in between 2 lipos(on their side). I place the spring on the scale and use hard ruler(unbendable) to press the spring down until the ruler touches the lipos.
Like that you can push each time equally as hard/far on all springs. Just write the scale readings down for all your springs and you have your own spring comparable chart.
